i think it looks fine.
but w/e i dunno exactly what were gonna do but hopefully he gets me the money so i can start on it.
Like I said not only does it look bad but you will have major cancelation!
i'm goin go quote amatt85 on this one ok from another thread on this same subject
id never do it. i think it looks goofy as hell. i mean it will probably be loud, but there are way too many factors to consider. i mean would u run different size tires on a vehicle? sure it will roll, but it will look stupid and ride like shit.
heres the link to the thread Mixing Sub Sizes
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
here is a complete right up from LSN2meBoom916 it can be done but u must know wat ur doin and not just throwin some different size subs in a box and callin it done
MIXING SUBWOOFER SIZES:
It can be done, and it can sound good/loud and clear and even BETTER than not mixing them.
It is BY NO MEANS easily done, so unless you have: A PHD in the Field of Acoustical engineering, A magical Ouija Board with all the answers, Or a CRAZY amount of LUCK, I would not even attempt it w/ out MUCHO RESEARCH.
From what I have read/seen/heard/figured out myself, mixing subs is just like mixing any other speakers in a system, the only difference is that subs GENERATE LOTSA FORCE.
Thus, they can have an impact on how other speakers/subs act when sharing airspace (BE-IT ENCLOSURE AIRSPACE or simply INTERIOR CABIN SPACE-i.e. same car/vehicle).
So the key to mixing and matching speakers/subs is really dependent on your ability to predict HOW those speakers/subs will interact in the same area (here's where the PHD comes in)
So to figure out "how 2 speakers/subs/assembly of moving parts" motivated by the "magic" of bipolar (+ & -) electricity (I know, it's kinda scary) will interact with each other and have any amount of accuracy...you kinda gotta know ALL the characteristics of ALL the parts and materials involved or do A RIDICULOUS amount of testing to form enough "generalizations" as to the outcomes of different combinations of parts so that you can say "this will work best/well/not suck".
That said, the main thing involved in successfully mixing/matching subs is being able to predict how those products will work w/ each other and that can be PLANNED as long as you know all the stuff I just said ^^^^^.
If you have a small sub that hits higher frequencies better than a big sub and a big sub that hits super low frequencies with ease, the ideal would be use them together and just tell them to only do what they are good at. The prob with that is in CAR AUDIO you are really limited on space and can't have 70 speakers each playing a tiny range fo freq's and you have to let a sub/speaker cover a wider RANGE of freq's.
It's just like A COMPONENT SET of midrange speakers. Think about GOOD comp sets. The XOVER IS KEY. It tells each super specialized speaker what freq's to play and all that impedence matched/hi-tech X-over talk that means your MB Quarts and Focal mids will sound awsome and much better than ur sony xploders and audiovox garbage.
So If you limit your mixed & matched subs, and only let them do what they are good at while keeping them from trying to do each others jobs (play the same freq's) you can actually build a SUPER EFFICIENT setup, that sounds better than a "normal" one.
If you crossover the subs/speakers at different freq's you should have no OVERLAP and thus no probs at all. Like maybe your 15's (or biggest woofers present) playing @10hz-35hz, the 12's @ 35hz- 50hz, 10's @ 50hz-80hz and some 8's @ 80-200hz, and your mids on up from there. you should have the most balanced system EVER.
Thats exactly how CRAZY home audio guys do it and they get some CRAZY sound outta a setup like that. The only diff is in a HOME audio environment you have less PRESSURE cuz the room/interior cabin is so much bigger and less limitations on space taken up by a sub box for 1-12" that's the size of ur fridge. It happens.
This topic has popped up so many times, ive said it before, and still stand by it, but
larger subs, seperate box, tune at a set number like 30hz
the smaller subs, seperate chambers, and tune 1octave highr, like 60hz
low pass the larger sub at 45hz
hp the smaller sub at 45hz
low pass the smaller sub at 90hz
Bamn, there ya go
recipe for a descent sounding multiple size sub set up
But having 4 of the same, or 2 of the same will work much better
Throwing 2 different size subs in a box, no seperation, or difference in equalization will st the subs off to have a mono tone bass, almost like a burp car
And the smaller woofer will definitly blow, no doubt about it
in seperate chambers, multiple size subs, the resonance from each size speaker will come together to make 1 tone, again like the second one
And you dont need a PHD to understand how this works, just a understanding of octaves, and wavelengths
simple stuff
well theyre going in a sealed box so they will have seperate chambers.
but he's lookin for something that has sq and still gets decently loud, he's not lookin for 150+ db.
something that does 135-140db and sounds good doing it will suit him just fine.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
B)
Amen Brother....directed at kwp369 and Forevrbumpin.
Edited by LSN2meBoom916
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
