lowrhadur Posted August 12, 2014 Report Posted August 12, 2014 02 Yukon Stock alternator New battery Pioneer 8600bs head unit pioneer 8604 powering kicker components and kicker 3 ways Pioneer 8601 running 2 ohms at 500watts rms on a Single kicker 15 Separate 4 gauge runs to each amp Big three upgrade Double grounds Front and rear Mids and highs play fine for 10-12 seconds then they just drop off. This happens mainly when my sub is on but has happened with it off. What could be the problem?
truthsayer Posted August 13, 2014 Report Posted August 13, 2014 Did you set your gains properly? Also remember those pioneer gm-d series amps are designed, as soon as they detect distortion, they will reduce the output to almost nothing. Try turning down the gains on your 8604. I have the 8604 and it performs great, as long as gains are set correctly. truthsayer
hispls Posted August 13, 2014 Report Posted August 13, 2014 Also would seem to me like you're over-driving the amp into protect.
truthsayer Posted August 13, 2014 Report Posted August 13, 2014 ^^^^^^^^^^^^ maybe i didn't make it to clear. When this happens you are clipping. The amp does not have a protect mode to shut it down. That's why as soon as it detects any clipping-distortion, it automatically reduces the output. truthsayer
lowrhadur Posted August 13, 2014 Author Report Posted August 13, 2014 Did you set your gains properly? Also remember those pioneer gm-d series amps are designed, as soon as they detect distortion, they will reduce the output to almost nothing. Try turning down the gains on your 8604. I have the 8604 and it performs great, as long as gains are set correctly. The gain is at normal. (4v which the head unit has 4v pre outs.
lowrhadur Posted August 13, 2014 Author Report Posted August 13, 2014 Both amps are mounted under rear seat. I was told it's not getting enough power. I need to move the amp closer to the head unit and shorten the rca's???
truthsayer Posted August 13, 2014 Report Posted August 13, 2014 Both amps are mounted under rear seat. I was told it's not getting enough power. I need to move the amp closer to the head unit and shorten the rca's??? I'm not sure how moving the amps and shorter rca's are going to help you. If you need more power, you probably need to have 0 gauge power wire. And i'm sure a better battery would help also. truthsayer
dolarbilz Posted August 13, 2014 Report Posted August 13, 2014 Did you set your gains properly? Also remember those pioneer gm-d series amps are designed, as soon as they detect distortion, they will reduce the output to almost nothing. Try turning down the gains on your 8604. I have the 8604 and it performs great, as long as gains are set correctly. Good info looking at that amp
_paralyzed_ Posted August 13, 2014 Report Posted August 13, 2014 Both amps are mounted under rear seat. I was told it's not getting enough power. I need to move the amp closer to the head unit and shorten the rca's??? I'm not sure how moving the amps and shorter rca's are going to help you. If you need more power, you probably need to have 0 gauge power wire. And i'm sure a better battery would help also. Not for under 1000 watts, 4 gauge is plenty and any battery can handle that.
