Moving from trunk to back set
rsfm089
If you have 33" width, subs are what 13.5 outside diameter? 2 puts them at 27" leaving 6" which is enough for up to a 5.25" wide port. Then if you have 18" tall the port ends up being able to go up to 5.25 x 16.5 should be plenty for 2 12s.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
finally! i had to do two boxes because otherwise once big wouldnt fit. Also you would be a lot happier with output if you sealed off the rear of your trunk. Bet that one sub sounds muddy and peaky. Your losing a lot by not having it sealed from the rear
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
1185597_10153233228065006_1521488627_n_z537004_10153233227660006_1211371477_n_zp
Can do it like this but to use the room better do a single chamber box with a port on either the driver side or passenger side.
From what I've read port on driver side usually gives better results on a meter. Not sure on that one though.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
1hdc312_zpsvr6p0a6r.jpg that's my box now if it gets longer I can't fit in my extra battery and amp in trunk I really don't want them in my back seat I will post a pic of how my old box was and I had to bust the seats out to fit it in
go taller and deeper, should be able to fit your battery in the rear behind wheel well. otherwise id rather have a battery in the back floor then your sub box just sitting there. i made mine a little wider thats why the box was set back a little bit so i could have the extra width.
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
shit ton-o-wire
Team SMD
  • Who's Online   0 Members, 0 Anonymous, 4010 Guests (See full list)
