KenC210 Posted August 18, 2014 Report Posted August 18, 2014 https://www.cnfdistribution.com/battery-terminals/terminal-blocks/battery-terminal-block-for-6-runs.html So I am wanting to use this as a power distribution block. The way it will be set up is, 2 positive runs of 1/0 ofc from the front battery to this battery terminal block in the link, then my sub amp and mids/high amp going to the distribution block. Would I be ok in doing that? Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Skater229 Posted August 18, 2014 Report Posted August 18, 2014 Here is another option... Gives you one more spot to connect... http://www.droppinhzcaraudio.com/toolmaker-7-input-lug-style-battery-terminals/ 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
KenC210 Posted August 18, 2014 Author Report Posted August 18, 2014 Here is another option... Gives you one more spot to connect... http://www.droppinhzcaraudio.com/toolmaker-7-input-lug-style-battery-terminals/ Thanks that would be better. I was more concerned if will be ok being only a small piece of aluminum. I am going to have dual runs on the sub amp and a single run going to the mids/highs. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Skater229 Posted August 18, 2014 Report Posted August 18, 2014 The toolmaker 7 spot looks to be a thicker plate... And i also like the offset battery connection... 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
KenC210 Posted August 18, 2014 Author Report Posted August 18, 2014 I already have one on the battery. I will be using this as distribution in the back. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
Skater229 Posted August 18, 2014 Report Posted August 18, 2014 No batts in the back? I was thinking you were connecting to a rear battery(ies) and were looking for a distro style block... It would still work for you but I would make sure the POS one is protected really well... 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
KenC210 Posted August 18, 2014 Author Report Posted August 18, 2014 No room for batteries in the back. I have a xs power 3100 in the front. I am finally getting around to finishing my Tundra build. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
audiofanaticz Posted August 18, 2014 Report Posted August 18, 2014 But these give you 1 more spot making it 8, and are the same price as the ones for 7. They are also offset for batteries like the d3100 or other center battery studded batteries. https://www.cnfdistribution.com/battery-terminals/terminal-blocks/battery-terminal-block-for-8-runs.html
KenC210 Posted August 18, 2014 Author Report Posted August 18, 2014 But these give you 1 more spot making it 8, and are the same price as the ones for 7. They are also offset for batteries like the d3100 or other center battery studded batteries. https://www.cnfdistribution.com/battery-terminals/terminal-blocks/battery-terminal-block-for-8-runs.html Good point. I already ordered the toolmaker though no need to cancel the order for unused slots. The build its going is to be the final and only build. Kids Cadi Power Wheel Build2007 Ford Escape Build2012 Toyota Corolla Build 2013 Toyota Tundra
