Distribution Terminal block question.
https://www.cnfdistribution.com/battery-terminals/terminal-blocks/battery-terminal-block-for-6-runs.html
So I am wanting to use this as a power distribution block. The way it will be set up is, 2 positive runs of 1/0 ofc from the front battery to this battery terminal block in the link, then my sub amp and mids/high amp going to the distribution block. Would I be ok in doing that?
Here is another option... Gives you one more spot to connect...
http://www.droppinhzcaraudio.com/toolmaker-7-input-lug-style-battery-terminals/
Pioneer AVHX-5800BHS
Alt CES 200/270+
Thanks that would be better. I was more concerned if will be ok being only a small piece of aluminum. I am going to have dual runs on the sub amp and a single run going to the mids/highs.
The toolmaker 7 spot looks to be a thicker plate... And i also like the offset battery connection...
Alt CES 200/270+
No batts in the back? I was thinking you were connecting to a rear battery(ies) and were looking for a distro style block... It would still work for you but I would make sure the POS one is protected really well...
Alt CES 200/270+
But these give you 1 more spot making it 8, and are the same price as the ones for 7.
They are also offset for batteries like the d3100 or other center battery studded batteries.
https://www.cnfdistribution.com/battery-terminals/terminal-blocks/battery-terminal-block-for-8-runs.html
Good point. I already ordered the toolmaker though no need to cancel the order for unused slots. The build its going is to be the final and only build.
  • Who's Online   0 Members, 0 Anonymous, 1579 Guests (See full list)
