Need help with a box design for dual SA8-V2 with specs
SAaudioUser
and joe can you show me exactly where i need to make the cutsout (exact spacing/position of them on the front of box ) im having a hard time with this, snice i have no one else to help me from where im from
You must've been the kind of kid that repeated "Mama" four dozen times till you got your Mom's attention. I'm sure JoeX has other priorities in life than to sit here and spoon feed newbs free box designs.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Ok OP the figure tells you the general location of the subs, they don't need to be exactly at one place but I will give you something:
That distance A is 15 1/4" which is the location of the brace then you can have the outer diameter of each sub 1" to the left and the right of A but if you give 1 1/4" nothing will happen.
just one more question,since you designed that box for for the rated power, would anything happen if i upgraded the amp from 1100 rms to 1400 rms ? feeding each sub 700rms ?
and dont forget the paypal :P
Not charging, the box will work with that amp as long as you use your subsonic filter as indicated above and you setup your gains properly. Also make sure you don't have leaks as you build, post in the amps section for help on how to set your gains properly.
  • Who's Online   0 Members, 0 Anonymous, 4973 Guests (See full list)
