dolarbilz Posted November 18, 2014 Report Posted November 18, 2014 Looks great ...what deck you have?if pioneer could be issue..notorious for engine noise
moredbs Posted November 18, 2014 Author Report Posted November 18, 2014 Looks great ...what deck you have?if pioneer could be issue..notorious for engine noise yes its a pioneer 4000 nex,any info would be gratefully appreciated.It only does it when i have both rca hooked up,if i split the signal with y adapters wouldn't that change the output?
dolarbilz Posted November 18, 2014 Report Posted November 18, 2014 Try grounding rca to back of deck...simple easy test before sending amps out. Basicly make a loop out of 18gauge to 14 gauge wire the size of the rca metal outside plug. slip it over.little solder don't hurt to hold in place.on other end of wire ad ring terminal .attach ring terminal to back of deck where there is a thread hole.if engine noise gone.done.
islandpride684 Posted November 18, 2014 Report Posted November 18, 2014 look up pico fuse... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
Miguels Posted November 29, 2014 Report Posted November 29, 2014 so ho is the build going? my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
moredbs Posted November 30, 2014 Author Report Posted November 30, 2014 so ho is the build going? Just sent the nendo amp back to be tested for noise.I tried everything but couldn't get rid of it. other than that just little stuff for now,tweets and vm-1 going in soon.
Miguels Posted November 30, 2014 Report Posted November 30, 2014 get a DC 175.4 to match the 9k my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
magillaru Posted December 15, 2014 Report Posted December 15, 2014 Tried to send a PM but didn't work... What bed liner did you use for the box? I was going to pick up some Herculiner tomorrow but it ain't cheap....yours looks like it turned out nice....hoping you used something less expensive??? Singer Alternators Team Asshole #anothershittysingerbuild
moredbs Posted December 15, 2014 Author Report Posted December 15, 2014 Tried to send a PM but didn't work... What bed liner did you use for the box? I was going to pick up some Herculiner tomorrow but it ain't cheap....yours looks like it turned out nice....hoping you used something less expensive??? i used the two part spray on raptor liner kit of amazon. 2 part spray on kits are the best.The kit i used came with 4 bottles,i used 3 but my box is bigger than yours.
magillaru Posted December 15, 2014 Report Posted December 15, 2014 Damn, that's even more.....I'm probably going to end up having to put it on after it's in the truck so I think I'm going to get the Herculiner since it rolls on.....it got good reviews on Amazon Thanks man! Singer Alternators Team Asshole #anothershittysingerbuild
