Triticum Agricolam Posted September 4, 2014 Report Posted September 4, 2014 Well the sanding was so the port wall inside the baffle would be flush against the actual box. Look below in the circles, more specifically the pink one where the double baffle meets the box wall it wasn't even and had a ledge probably 1/8 - 1/4 of an inch would I assume would be bad for the air flow, so I sanded it. Yeah, that was a good idea to sand that flush, like you said, it would be bad for airflow to have a ledge there. For future reference, if you have access to a router you could use a flush trim bit to trim that inside edge (or any edge) flush with the piece beneath it in like 30 seconds. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Syphlyn Posted September 5, 2014 Author Report Posted September 5, 2014 Looks really clean, nice job. I am puzzled though on why you said you didn't glue one of the sides and your baffle though? You mentioned not doing it due to needing to install bolts for wire connections, but that can be done through the sub cutout lol. Such a long wait on your woofer and alt, that would drive me crazy! Gives all the time in the world for perfecting everything on the box and having the car completely ready to plug and play though. Yeah it's just easier to access from the side then from the top. Haven't decided where the brass bolts are going yet. The top baffle isn't on because I didn't get around to it and still somewhat trying to figure out if cutting the top piece out more so the woofer will mount flush. Not sure if it'll be strong enough that way to support the Zv4. Syphlyns 2000 F150 4.6L V8 H/U: Kendwood KDC-X898 Speakers: 4 x Alpine SPR-68 Speakers 4 Channel Amp: Alpine PDX-F4 Sub: Sundown Zv4 12 Sub Amp: Sundown SAZ-2000D Box: 2.75 Cu Ft @ 31Hz Alternator: Mechman 250A elite series Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
deadbroke Posted September 9, 2014 Report Posted September 9, 2014 Looks good man! Looks like that box is deep too where are you planning on putting it? Like how you did the countersinking
Syphlyn Posted September 9, 2014 Author Report Posted September 9, 2014 Looks good man! Looks like that box is deep too where are you planning on putting it? Like how you did the countersinking In the back of my F150 extended cab. Sub/port will be firing up. Height: 29.5" Width: 17" Depth: 18" Syphlyns 2000 F150 4.6L V8 H/U: Kendwood KDC-X898 Speakers: 4 x Alpine SPR-68 Speakers 4 Channel Amp: Alpine PDX-F4 Sub: Sundown Zv4 12 Sub Amp: Sundown SAZ-2000D Box: 2.75 Cu Ft @ 31Hz Alternator: Mechman 250A elite series Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
fredz89 Posted September 9, 2014 Report Posted September 9, 2014 looks good man, never would have thought it was your first box.
