New to car audio!! In the process of building an affordable sq system, with some damn good thump!
So far i purchased two FI Q 12's dual 2 ohm, no cooling, no chamfer, high qts yes, heat ring yes, rms 1500..
Now searching for (2) clean, and effecient mono amps to push them seperately. Really interested in rockford fosgate, but not sure which ones to use as they have several lines to choose from. I am leaning towards the rf t1000 bd or the t1500 1bdcp.. Will the t1000 (birthsheets usually around 1300+rms) be enough or just right? will these subs reached their potential on this amp? Or will the t1500 (birthsheets 1800+rms) be perfect or too much for these subs? Any positive direction i cn get pointed towards is appreciated fellas!
SQ huh ... I'd go with a single class A/B 2 channel mono and run those subs at 8 ohms ... 28 htz tuning should make for an impressive setup if done correctly ...
Skippy main reason so I cn split a sub amp combo with another car I'm gonna have later.
Cablguy, what brand would you recommend for an amp in this class? Also are you suggesting 1 or 2 amps? Minimum/maximum rms rating? Im learning not to under-power subs but dont hv a clue what will not be enough, and what is too much?? My budget for sub amp is around $600 if that helps..
Thanks fellas for chiming in
those subs are rated at what 1250/1500w rms? so i would get a solid 2500w amp. you can get a real nice sundown 2500/3000 for under 6 or a DC 3k for under $600.
I'd go with almost anything but.
i can't justify spending $600 for 1800w... not when you can get almost 4,000w for $600
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
ok 2 sundown 1500s for $300 a pop. one will do more then that rf for half the price.
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
I really hate reading AJ11 replies. 9/10 times their worthless.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
  • Who's Online   0 Members, 0 Anonymous, 1403 Guests (See full list)
