TheMonolith2001 Posted September 7, 2014 Report Posted September 7, 2014 I would imagine it is just a relay in there that would eventually wear out, but say I am stopping the vehicle and starting it again every 15 minutes or so. and I do this for a few hours a few days a week. Is this too much? I must admit I have never seen an amp just stop turning on unless it blew up due to misuse but that doesn't mean it can't happen I guess. Should I probably be more worried about my battery? Voltage always reads OK so far.
SIDE SHOW Posted September 8, 2014 Report Posted September 8, 2014 what u running? is you say you have a boss amp then yes it'll kill it lol
islandpride684 Posted September 8, 2014 Report Posted September 8, 2014 Put a switch on it... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
Jessica Posted September 8, 2014 Report Posted September 8, 2014 idk, ive had a few drinks so.... Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
REH Posted September 8, 2014 Report Posted September 8, 2014 You really shouldn't have to worry about this at all.
Triticum Agricolam Posted September 8, 2014 Report Posted September 8, 2014 When I looked up the stats on relays in the past they all had mean time between failures of around 50,000 cycles or more. I imagine the relays inside the amp are no different. You are never going to get anywhere near 50,000 cycles. Turning it on and off 10 times a day, every day, for 10 years only gets you a little over half way to that. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
TheMonolith2001 Posted September 8, 2014 Author Report Posted September 8, 2014 Ah that is a good idea, I never thought to look up how many cycles the relays are rated for. They are both old school PPI amps so while they have been switched on and off many times by now they probably used high quality parts that are still nowhere near the max they are rated for and will probably last even longer than that. I COULD put a switch on it but I was asking because I do want it to come back on every time I start the vehicle again if it was safe which it seems it is.
