69 Camaro w/ 2 JL Audio 8 w3v4 on JL HD 600/4
69camaro
Guys, I think I may have made a horrible box design mistake. I made a ported box almost double the recommended size of JL's recommendation. I don't recall the dimensions off hand but the cubic feet was .7 per chamber. I also used 3" diameter PVC for the port. It is 18" measuring from one opening to the other. (diagonal)
The sound quality is really good on the lower notes but once it starts getting into upper lower notes the sound level drops off quite a bit. So much that it sounds really weird. On rap music you can't really tell, but on rock n roll it sounds..... HORRIBLE.
The ports are routed out of the chamber.
Is this a direct relation into building the box to big ? The 69 Camaro has rear deck. The speakers firing upward in the cabin along with the ports.
Any pics of car and enclosure
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
If you run the specs through WinISD pro, that should ho you determine what your freq response is doing, and perhaps what you need to do to fix it.
May be as simple as removing some net airspace (glue some 2x4 inside to take up space) or shorten your port. It may be a simple fix do you don't have to scrap the whole box.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
glad you figured out how to post pics
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
sorry for the pics being so large. Next time I will edit to a smaller size
box dimensions are
13.5 x 15.5 x 10 these are outside dimensions of the box
If my figures are right and I take off 3/4" from each dimension it works out to right at 1 cu ft before speaker displacement.
Looks a lot bigger than the dims you posted.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
  • Who's Online   0 Members, 0 Anonymous, 2989 Guests (See full list)
