Tigerboy Posted September 28, 2014 Report Posted September 28, 2014 hey guys, so when i turn my stereo up to the highest loudness i want it at the voltage drops to 12.5v over time. i was looking at adding a battery in the trunk but then i saw this article, and didnt know how to proceed from here. http://cartech.about.com/od/Car-Audio/f/Do-I-Need-An-Extra-Battery-For-My-High-End-Car-Audio-System.htm basically saying adding a second battery just stresses your alt more and doesnt help. i know thats true for capacitors. but i thought batterys were different because they dont drop all the power out at once in a single burp. so i dont know if adding a second battery will help my situation. or if i need a H/O alternator.i currently have a 2007 honda civic lx. with: stock 80A alternator an optima yellowtop d51r (35Ah i believe) big 3 with 4ga wire two amps, one for the front speakers and one for the sub, currently no rear speakers. but would like to add if have the power to drive them 2x 75w front speakers @4ohms 1x 300-400w sub @4ohms Civic Build Trunk Build Log
MrLandedra Posted September 28, 2014 Report Posted September 28, 2014 I would agree, adding a second battery will just increase the amount of power to pull from, although I believe that it will only decrease still because as it sits, the alt doesn't maintain. I'd say get a H/O alt for a couple reasons. You can actually find a H/O alt for around the same price as a good battery, also overall it's a great improvement to the car's electrical system. believe half of what you see and none of what you hear lol. 2003 Ford Taurus SEL JVC KD-R520 4 JL ZR-525CSI 5.25 Mids 4 JL ZR100-CT Highs 1 18" RE Sx Dual 4 ohm wired parallel to 2 ohms 1 Kicker CX1200.1 (Bass) 1 DD S4B (Mids) 2 Optima Yellow Tops 200a Alt.
slowfkncar Posted September 28, 2014 Report Posted September 28, 2014 hey guys, so when i turn my stereo up to the highest loudness i want it at the voltage drops to 12.5v over time. i was looking at adding a battery in the trunk but then i saw this article, and didnt know how to proceed from here. http://cartech.about.com/od/Car-Audio/f/Do-I-Need-An-Extra-Battery-For-My-High-End-Car-Audio-System.htm basically saying adding a second battery just stresses your alt more and doesnt help. i know thats true for capacitors. but i thought batterys were different because they dont drop all the power out at once in a single burp. so i dont know if adding a second battery will help my situation. or if i need a H/O alternator. i currently have a 2007 honda civic lx. with: stock 80A alternator an optima yellowtop d51r (35Ah i believe) big 3 with 4ga wire two amps, one for the front speakers and one for the sub, currently no rear speakers. but would like to add if have the power to drive them 2x 75w front speakers @4ohms 1x 300-400w sub @4ohms Have you bypassed your electronic load detector? Your car will drop to 12.5/7 during certain situations to save you gas. Anything connected straight to your battery will not show as a load on the ECU since the current isnt passing through the load detector. In other words,your alternator will shut on and off while full tilting your sounds. If you have not bypassed the ELD yet, then this http://www.stevemeadedesigns.com/board/topic/139844-how-to-eld-bypass-for-honda-civicaccordfit/ is probably what you are looking for
Kyblack76 Posted September 28, 2014 Report Posted September 28, 2014 Where are you reading the voltage at? your running around150-200watts aftermarket, and drop to rest? That is silly harsh. Is this at idle or rev? and "how much time?" Is your battery resting ok? (imho your running nothing, power wise. Seeing battery rest tells me its your car's "brain" doing. Or some connections are not up to snuff. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
slowfkncar Posted September 28, 2014 Report Posted September 28, 2014 hey guys, so when i turn my stereo up to the highest loudness i want it at the voltage drops to 12.5v over time. i was looking at adding a battery in the trunk but then i saw this article, and didnt know how to proceed from here. http://cartech.about.com/od/Car-Audio/f/Do-I-Need-An-Extra-Battery-For-My-High-End-Car-Audio-System.htm basically saying adding a second battery just stresses your alt more and doesnt help. i know thats true for capacitors. but i thought batterys were different because they dont drop all the power out at once in a single burp. so i dont know if adding a second battery will help my situation. or if i need a H/O alternator. i currently have a 2007 honda civic lx. with: stock 80A alternator an optima yellowtop d51r (35Ah i believe) big 3 with 4ga wire two amps, one for the front speakers and one for the sub, currently no rear speakers. but would like to add if have the power to drive them 2x 75w front speakers @4ohms 1x 300-400w sub @4ohms Have you bypassed your electronic load detector? Your car will drop to 12.5/7 during certain situations to save you gas. Anything connected straight to your battery will not show as a load on the ECU since the current isnt passing through the load detector. In other words,your alternator will shut on and off while full tilting your sounds. Where are you reading the voltage at? your running around150-200watts aftermarket, and drop to rest? That is silly harsh. Is this at idle or rev? and "how much time?" Is your battery resting ok? (imho your running nothing, power wise. Seeing battery rest tells me its your car's "brain" doing. Or some connections are not up to snuff. He is running on battery power. I bet if he starts his car fresh in the morning his voltage wont drop lower then 13.5 untill the ecu senses that the vehicle is warmed up. This is common on most honda/acura's Sorry for the double post. Not directed at you.
slowfkncar Posted September 28, 2014 Report Posted September 28, 2014 hey guys, so when i turn my stereo up to the highest loudness i want it at the voltage drops to 12.5v over time. i was looking at adding a battery in the trunk but then i saw this article, and didnt know how to proceed from here. http://cartech.about.com/od/Car-Audio/f/Do-I-Need-An-Extra-Battery-For-My-High-End-Car-Audio-System.htm basically saying adding a second battery just stresses your alt more and doesnt help. i know thats true for capacitors. but i thought batterys were different because they dont drop all the power out at once in a single burp. so i dont know if adding a second battery will help my situation. or if i need a H/O alternator. i currently have a 2007 honda civic lx. with: stock 80A alternator an optima yellowtop d51r (35Ah i believe) big 3 with 4ga wire two amps, one for the front speakers and one for the sub, currently no rear speakers. but would like to add if have the power to drive them 2x 75w front speakers @4ohms 1x 300-400w sub @4ohms Here you go! http://www.8thcivic.com/forums/i-c-e-electrical-security-navigation/281279-unplug-eld.html
Tigerboy Posted October 7, 2014 Author Report Posted October 7, 2014 Thanks guys ill check out the ELD bypass Civic Build Trunk Build Log
GSanders17 Posted October 7, 2014 Report Posted October 7, 2014 I drive civics, you definitely should bypass that damn eld. I would also say if you ever intend to run more power definitely upgrade your alternator, it's totally worth the money!
Guest Posted October 7, 2014 Report Posted October 7, 2014 if i could run a soundqubed 1200d and a fosgate 200w 4 channel on a 70 amp alt, you can run less than half that power.
