Efficient 2k amp for under $350?
AstoSoup
get an amp you can run @.5 once you get your alt, just run it at @2 for the time being.
I think that CT 1400 is the problem solver! Didn't even think of the possibility they could do 0.5ohm :shrug:
yea, those amps are supposed to do more like 1800 watts at 1 ohm so if you run it at 0.5 (at your own risk but some people do it) it will slam those subs
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Yea they are monsters, for sure! Steve dyno'd one and got close to 2400W @.5ohm :) I guess they can handle it daily without a problem. Will most likely be finding out soon!
Head Unit - Clarion VX709 7" DVD Touchscreen
Mid/Highs - Front Doors - RF Prime 6.5" component mids.
A. Pillars - RF Punch component tweets.
B. Pillars - RF Prime component tweets.
Rear Doors - RF Punch 5.25" mids.
RF Punch 3-way passive X-overs.
Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS.
Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider.
Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS.
Box - 9.6 cu^3 net @35Hz, three 6" aero's.
Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand)
Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
You're asking for "efficient" and .5 ohm both. You aren't going to find that, I skimmed over the comments and did not see that in there. If you want to be efficient, with (2) dual 2's, you'll need to run them at 2 ohms... and 2k @ 2 isn't going to be real cheap.
So are you guys that are telling him to buy an amp that's rated at 1 ohm and run it .5 ohm going to buy him a new amp if it blows?
Being that amps @0.5ohms are not efficient, HOW much efficiency would be lost on an amp that does rated @1ohm @12.6v? Would it take a full 14.4v to do rated at .5, or more?
Also, what about two, 1k @1ohm amps gain matched? Or would strapping them be better? Never ran two sub amps before so have no experience and little knowledge on doing so...
you can get rated power with an amp with 50% efficiency. the only issue will be that you need a shit load of electrical to make that power.
Thats what I was trying to avoid, needing a wad of batteries to get to rated power. I have a Kinetik 850a cell in there now and plan on adding a second before installing the second 15. Big 3 is done, stock alt. is 130a. I am going to get a DC Power 230a down the road but want to deal with first things first. With the two cells, big 3 and a 130a alt., will that be enough to power the CT 1400.1D @0.5ohms? Just don't want to get the amp and find out I need more batteries or a new alternator before I can even use it.
  • Who's Online   2 Members, 1 Anonymous, 482 Guests (See full list)
