80 PRS guys, come inside please
So my 80 PRS is on the way. i already run active on my b2 quattro and my b2 zero.1. But i haven't bought a CC1, I've always borrowed dubndodge's but paying shipping both ways about 5 times already ($20 a use) i could have bought my own.
Im going to be running active on the 80PRS, (I'm assuming the 3 way active, highs on my tweeters, mid on my 6.5's, and low for my subs)
Correct me of thats the wrong function of the head unit but i was almost positive it had a way to treat it like a 3 way active set up.
Being that it has all of the crossovers in the head unit, would i not need a CC1 to tune my system? Just dd1 everything correctly and then go to the front and set up all the filters and TA?
Thanks in advance.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Yes. There is a switch on the back that will make the RCA outputs act as mid high low. You just set the filters on the hu
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
Yep. The CC1 won't do you any good with the 80PRS... has fixed filter points.
2007 Pacifica
Sounds like you should be good just obviously switch the amp crossovers back to full range or you might have some weird results.
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 1164 Guests (See full list)
