Scratchy noise problem when you open the door
Swordlordboy1234
Video below showing it. I soldered all the wires together. Used quick disconnects very close to the tweeter and the mid in each door. Thats the only thing that has changed in the last 3 days since i installed these speakers. Passenger door doesn't make that noise. Could it just be a poor solder job? Anything else i should check?
It does not make noise when the head unit is off (and door is opened / closed)
Engine on or off seems to have no relevance either.
Speakers play fine as long as the door isn't being moved (opened or closed), ill be fixing them shortly after some suggestions are made.
Thanks again!
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
check the speaker wire.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I think it's either the connections or a pinched wire when the door moves. It seems like the sound happens when the wires move around opening and closing the door. Maybe a damaged wire in the bundle.
From the vid, your ride has a nice install job, and you soldered the wires
it's surprising your having a problem. I just fixed one of my sounds probs.
Dam box managed to pinch one of my RCAs, alt wine like a mofo.
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
