join with help building a 1000 dollar budget gaming pc
An SSD will with no doubt be better than any hard drive.
It's not just game load times, but with pixel rendering and texture quality SSDs help access that information much better allowing a more stable frame-rate with very low frame times.
Well said^ Even if your CPU and RAM are rendering things quickly, the information will bottleneck with a HD not capable of high read/write times. Just think of it like this, a chain is only as strong as it's weakest link. Just like in car audio, you could have two, DC 5k amps and without a good electrical system, they will only distribute so much power. When upgrading one component, the rest must be upgraded to keep the whole unit strong. I know my analogies suck lol, but you get the drift!
Head Unit - Clarion VX709 7" DVD Touchscreen
Mid/Highs - Front Doors - RF Prime 6.5" component mids.
A. Pillars - RF Punch component tweets.
B. Pillars - RF Prime component tweets.
Rear Doors - RF Punch 5.25" mids.
RF Punch 3-way passive X-overs.
Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS.
Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider.
Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS.
Box - 9.6 cu^3 net @35Hz, three 6" aero's.
Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand)
Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
Would I love to have a 1tb samsung. Fuck yeah!
Its just not high on my list of shit to get.
I need a big ass one cuz so many games. Would be a waste for me just to put OS on one. Is my opinion though.
I know it would help. But I pull 100+frames in pretty much everything I play so the money to performance ratio isn't there for me.
98 Mustang GT
Singer 320
2 12" Incriminator Death Penalties
1 SAZ-2500dv2
2 D3100,1 D3400
2 Crescendo CZ-65
SAX-100.2
Door panels by Diablo Kustomz
Here are my specs. I have YET to encounter a game I can't max out on ultra settings and it's AMD/Radeon.
Custom Built:
CPU - AMD FX-8350 3.5Ghz 8 Core (@4.40Ghz, Liquid), up to 2166Mhz FSB, 16Mb-32way Main Cache, 1Mb, 64 way Core Cache (17Mb TOTAL Cache)
CPU Cooling - Corsair Hydro Series H60, High Performance Liquid CPU Cooler, 120mm fluid dynamic fan.
Memory - 16GB G. Skill RipjawsX Series DDR3-1866, 9-10-9-28(DC)(4x4GB)
Motherboard - Gigabyte GA990FX-UD3, 990FX chipset, 4 way Xfire ready, 2x Pciex16, Anti ESD, Heat Pipe NB/VRM cooling, Dual UEFI/GUI BIOS, SATA 6Gb/s, USB 3.0, eSata 3.0, Optical out, Military Grade, Solid Caps.
GPU - (2) Crossfired Sapphire Radeon R9-270x OC Edition, 2GB 256 bit, 1280 Stream Processors, Vapor-X cooling, HDMI, dual DVI, Pcie 3.0.
Hard Drive(s) -
System - 250GB Samsung 840 EVO SSD. SATA 6Gb/s, 512Mb cache, Sus. Read 540Mb/s, Sus. Write 520Mb/s. 4k Random. Read, 97,000 IOPS, 4k Random Write, 66,000 IOPS
Storage - 500GB WD SATA III, 7200RPM (internal)
(3) 1TB WD SATA III, eSata externals.
Case - In-Win Plastic and Titanium, 6x 120mm fans, bottom mount PSU w/ 140mm intake fan. (white with red L.E.D fans)
PSU - Raidmax 735w Full Modular, 4x +12v rails, SLI/Xfire certified, Active PFC, 80 Plus Bronze,140mm blue L.E.D liquid bearing intake fan.
O.S - Windows 7 Ultimate X64
DVD - Plextor Duplication Grade DVD-R/RW. 1mb cache.
Extras -
Front bay, 5 Channel digital touch screen fan controller/ temp. monitor. Controls each fan seperatly as well as temperature in 5 different zones.
Coolermaster Storm Devastator Keyboard/Mouse. blue L.E.D backlit (both), 2000+ DPI mouse.
Lol, me too! Them EVO 1Tb's are crazy expensive though and I need new amps :/ The decision between my PC's and my system is always a tough one, haha
Too many hobbies! Not enough money!
#thestruggle
98 Mustang GT
Singer 320
1 SAZ-2500dv2
2 D3100,1 D3400
2 Crescendo CZ-65
SAX-100.2
#thestruggle
Them Death Penalties gotta be slammin though :)
#thestruggle
A little haha
Also op a good way to save is see if there's cpu and mobo combo deals etc. When I built mine I saved about 200 bucke with various deals and combos.
98 Mustang GT
Singer 320
1 SAZ-2500dv2
2 D3100,1 D3400
2 Crescendo CZ-65
SAX-100.2
well, i use an i5 3.0 and i can play a game like d3 at max settings, steam it at 720p 2800kbit and have my stream open and watch it no issue. i almost bought an amd, and i am a huge fan of amd. but after looking at benchmarks then actually reading some tests/reviews done with actual applications on both i found the i5 was more robust at raw number crunching. So if you want to do something other than play a game i would go intel. if you just want a stack of cores that second as a easy-bake oven go amd.
Lol, easy bake? I know AMD run hotter but the FX series are much cooler. My CPU idles at around 65f on liquid and peaks at 85f. Never seen an FX go over 100f on air, in a case with good airflow. A lot of people are Intel fanatics but I bet they haven't used an FX series.
I have an 8350, 290 and a EVO SSD. I do notice my CPU bottleneck quite a bit in large complicated scenes.
Krakin's Home Dipole Project
  • Who's Online   1 Member, 0 Anonymous, 1697 Guests (See full list)
