'85 Trooper 6 X 15" Dd Audio Clamshell, 16000wrms
Did bugger all work this afternoon, I was rather pissed off but I forced myself to do some.
A little bit of sanding, top piece in and filled the rest of the screw holes, ready to start the baffles now! :) Getting exciting, it's starting to look more and more like a box every day!
Posted Image
Thanks guys
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
Posted Image
Just gotta wait for them to arrive.
My Youtube Videos
Posted Image
9515?
2015 Honda Civic LX 4dr | 24k miles
Stock H/U and mids/highs
Power Acoustik GW3-12" D2 Sub
HiFonics BXX1200.1D @ 1ohm
Random 2.5^3' dual ported box
NVX LOC
Stinger wiring throughout
1977 Chevy SWB
Cammed 350
Dual exhaust
Cheap Wish stereo
Here's tonight's efforts guys. I know it's nothing much but it should tide over until I get some decent time to work on it on the weekend. My goal tonight was to get the bottom baffle somewhat complete. Here's what I did.
Cut the three pieces out, made sure they fit and cut the angle to suit. Screwed them together to hold them in one position.
Posted Image
Test fitted to make sure I can fit rows of 3 15" subs wide, it fits pretty easily. These are not the subs I am using, but I am using them to make sure the subs I do install fit. These are nice subs anyway though!
Posted Image
Marked out the positions for the holes. The router will attach to the centres of the X.
Posted Image
Test marks by the router to make sure I didn't screw up.
Posted Image
Then it's the 'here goes', cut all the way through, damn it looks messy so far!
Posted Image
Time to make some slightly smaller holes, same procedure as before:
Cutting through:
Posted Image
POP!:
Posted Image
Once I've done three layers it's time to make sure they all fit together, which they do.
Posted Image
Does the sub fit?
Posted Image
Yes it does, and because the first hole is large, the sub sits nice and flush in the baffle. It's not glued together yet so you can see gaps everywhere.
Posted Image
Edges tidied up, and it all lined up pretty well.. also gave it a light round over to make sure it doesn't chip much and to give it a neater finish.
My Youtube Videos
Then I screwed and glued them into the car one at a time. Once they were all in a got rid of the nasty leaks of glue coming from every joint and mounted the temporary subs to see what it looks like. I'm pretty happy, it's finally starting to look like something.
Posted Image
Posted Image
Posted Image
Can't decide whether to mount them normal or inverted, what do you guys think?
Posted Image
Tomorrows effort: Start on top baffle and also finish bracing the bottom panel.
Cheers for looking guys.
My Youtube Videos
man i want some 15s so bad.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 1194 Guests (See full list)
