'85 Trooper 6 X 15" Dd Audio Clamshell, 16000wrms
Thanks guys although I don't think it will be seeing more power. Each sub is seeing around 2000wrms. the Youtube compression kills all the flex. It looks tame in the vid, can't even see the hair moving :(
FYI I burped 141.9dBs in my SPL run just for a laugh, hehe. People got upset when I didn't turn it up, but that's all I needed to win.
Is there a way you could upload an uncompressed version to megaupload or something?
I wouldn't mind seeing this in full quality
  • 1 month later...
any updates lately?
awesome vids so far... need more tho :P
oh and i noticed the fronts are gone in the new vids, whats going on there?
^^^ clicky pics for build logs ^^^
Didn't even realise this topic was bumped, well here's what's going on for the fronts.
Here's where I started. Standard door card, looks shit. I should have changed it a long time ago but never 100% worked out what's happening in the frontstage. The overall look of this just dragged the interior down, most of the interior is black but these light brown trims just ruin it. They are dirty, falling to bits and need changing!
These doors have lots of room to add speakers so shouldn't be painful to make look a lil better.
Posted Image
First I strip off this 'padded' top trim to reveal shiny red duco underneath. This was the 'upmarket model' so it got the little bit of vinyl ontop the door, whoop-di-doo, Basil. I ripped it off and shined up the paint because it will need to match black.
Posted Image
How it looked just removing that trash
Posted Image
Door card removed, very very scarce Dynamat job, won't look like this for long!
Posted Image
Stripping the ugly material off the stock door card.
Posted Image
Tracing the shape onto a new piece of 3mm MDF, the standard card was rotten and cracked and will be binned :)
Posted Image
Test fit on the door
Posted Image
Test fit with the trimmings, note the ashtray, map pocket etc. have all been removed permanently.
Posted Image
Some new clips, these will (try to) help the door card cling to the door at 150+ :P
Posted Image
Old clip (Left) vs new clip, (Right)
Posted Image
A couple of days passed and a package arrived, mystery box, what's inside?
Posted Image
We'll open that later, here's another bulk pack of Dynamat Extreme, 36ft^2 for the front doors :D
Posted Image
Here's what was in the mystery box, should sort out my lack of high frequencies I hope! Huge thanks to Digital Designs Australia for kindly providing the speakers and Alberts Car Stereo also for helping me out along the way and giving me great deals.
Should be fun to make fit!
Posted Image
Very basic looking speaker but should be all business when it comes time to make sound!
Posted Image
Thanks for looking
36CFDEF1-F93D-4FA3-9934-64EE2EC94080-2856-0000071FCFA47672.png.ebe82e417eabc5f239a4adf293b099f9.png
Previous 150+ daily rides:
Volvo 240 wagon 2 x DD Audio 9915s walled, Isuzu Trooper 6 x DD Audio 3515s walled clamshell, Lexus LX470  2 x Kicked Solo X 18s, Lexus LS400 4  x American Bass HD18 walled
SMD - System of The Month August 2008
My Youtube Videos
Early days, working out the position for the speakers.
Posted Image
Make sure they all sit at the same angle.
Posted Image
Trace an outline on it
Posted Image
The dark line is where I'll be cutting, gives you an idea of the shape.
Posted Image
Posted Image
Grilles sitting in place for an idea how it sits
Posted Image
A quick whisk with the jigsaw and we have the first piece
Posted Image
Started cutting speaker holes, they are quite deep so I need a decent spacer to get them to fit
Posted Image
Cutting and routering the edges
Posted Image
Cut out, but still rough, requires sanding
Posted Image
My Youtube Videos
The door trim, clearance cut out revealing the metal behind.
Posted Image
The shape traced onto the metal with a permanent marker.
Posted Image
Took a deep breath and started cutting the metal away. A good idea if you're going to try this, wind the window up so the saw doesn't hit the glass, just a hint :)
Posted Image
Test fit of the grilles on the door
Posted Image
Just the speakers mounted, looking finally like something
Posted Image
My Youtube Videos
you know what it is
current SQ car:
98 holden combo
jvc usb headunit
4 prv audio bullet tweeters
8 prv audio neo 8"
16 obsidian audio v2 12" woofers
8 crescendo bc2000d
10 120 a/h Schneider agm batts
Mechman SMD 350 amp H/O alternator (dual alt setup)
All Shok industries cables
..... pretty soft really
I wasn't happy with the depth issue and wasn't able to wind the window down as far as I'd like, so time to change things.
So off it comes
Posted Image
Trace it, cut a new piece, but leave a rough gap of 5-10mm around the edge, why? You'll see soon
Jigsawin
Posted Image
Screw them together, see the gap around the edge
Posted Image
Now we use a router flush trim to get them the same
Posted Image
Now we have two pieces the same
Posted Image
While I was working on that, I set up this 'jig'
Posted Image
The side intrusion bar in the door had broken from the door skin so I attempted to glue it back onto the skin using a polyurethane glue, the battery adds weight to hold the two together whilst it dries.
Still needs sanding, but getting there :)
Posted Image
Here's the result of emptying the contents of your bulk pack on both front doors, I definitely noticed a difference, doors are MUCH heavier now, and close with a REAL thud this time :)
Posted Image
Solid as a rock! and sealed up, no service holes. Shouldn't vibrate and should give me some good midbass!
Posted Image
Put the door card back on!
Posted Image
My Youtube Videos
Started loading the speakers up, much better depth now :)
Posted Image
Posted Image
Can't wait to finish it
Posted Image
Posted Image
But the driver's side needs finishing. This is all only a dry assembly, need to pull it all apart again to assemble it properly, then get it trimmed etc.
Posted Image
My Youtube Videos
  • Who's Online   0 Members, 0 Anonymous, 7071 Guests (See full list)
