Soundqubed Q1.3500.1 -- .5ohm stable
Yukonboi
I never recommend below one ohm for someone I don't personally know either. It's the new sexy thing to run your amp at half ohm with a 4th order tuned to 30Hz built with the sole purpose hair trick only.
With that alt and those batts, you're not staying in the 14s. If you do, your box is crazy inefficient and you're not getting the 4000+ Watts that amp has to offer. If YOU ARE getting the power, you're going to dip voltage.
Dam I really want to buy but it makes me nervous under manufactures ratings no matter correct voltage or not I can pick it up for $500 and it's only 4 months old
If you dont want to buy it then let me know how i can. I'm looking to get one, but I'm gonna run it at 2ohms. I get a discount from SQ'ed but I'd rather not pay more than i have to.
Here is the thing: We can tell you all day, this should work and that should work. You are assuming the risk though, so you have to be prepared if something goes wrong. It's perfectly okay to drop into the 12s, which is likely where you'll be with your electrical setup.
  • 3 months later...
Did you get it? What is your voltage like?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
