Yukonboi Posted October 7, 2014 Report Posted October 7, 2014 I'm about to purchase one but wanting to know if it can run .5ohm with out problems other people say it can but is there proof any where out there??? Any info is greatly appreciated before I make this pricey purchase
CleanSierra Posted October 7, 2014 Report Posted October 7, 2014 Local friend runs his hard at .5 ohms daily and has plenty of alt and bank to back that up. If you do too, let er rip. Im not the one you want to try to troll. Just a fyi for you.
boom50cal Posted October 7, 2014 Report Posted October 7, 2014 Not recommending that you do, but if you're electrical is up to par, and you are aware of the risks involved with running equipment in ways they are not designed to... Then do it. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
P4killer_ Posted October 7, 2014 Report Posted October 7, 2014 I ran mine at .0001 ohm of a AA battery. Those amps are built like a tank.. Get a few decent batts and watch the voltage. Use ur brain itll be fine. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
Yukonboi Posted October 8, 2014 Author Report Posted October 8, 2014 I have a 300amp Ohio gen alt 2- kinetik hc2000s and 2 runs of 0/1 my voltage stays pretty steady at around 14.4 drops a little below 14 full till on old amp what do you guys think , will this work? Also have big 3 done
CleanSierra Posted October 8, 2014 Report Posted October 8, 2014 That's probably enough to get the job done, yeah. Im not the one you want to try to troll. Just a fyi for you.
Karkov Posted October 8, 2014 Report Posted October 8, 2014 What's your old amp? That thing is gonna suck lots of juice at 0.5 ohms. Just watch voltage VERY close with a good meter. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
Yukonboi Posted October 8, 2014 Author Report Posted October 8, 2014 Old amps where not near what this amp will be but I had two hifonics Brutus BRX2400.1D at 1 ohm
Yukonboi Posted October 8, 2014 Author Report Posted October 8, 2014 What is the voltage I should hopefully say around mid 14s or so
Cardboardcat15 Posted October 8, 2014 Report Posted October 8, 2014 I never recommend running under manufacturers ratings. But if youve got mad reserve, you could probably get away with it. My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
