6 t1 12s
kong
Well here is where i need a litle help. I have a 2004 cadillac srx, and i can only use the rear portion. Max length 36 width 38 and height 26. I wanna go ported and tune it high. I have 3 1500 bds anyone have any recommendations?
Now you see why im running into problems lol. Ive tried everything i know and cant figure a way to do it. So i wanted to pick everyones brain before i put that idea in a grave
Because i cant fit 8 lol the srx is the station wagon. Crossover lol. I was gonna try a 4th order but well as u know i have no space
where theres a will theres a wall.......
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
First off, nice ride! Them SRX's are sweet for sure! If you can't fit all 6, i'm sure you have room for 4.
http://image.minitruckinweb.com/f/features/8542497+w799+h499+cr1+ar0/0612mt_07_z%2Bcustom_2004_cadillac_srx%2Bsub_woofers.jpg
^There is the same vehicle with three 15's in the back, which takes up most of the room but they're also 15's. Plus them are Lightning Audio so.... they don't need a ton of airspace lol. It seems mathematically possible though, assuming you can use the ENTIRE cargo space for an enclosure. Your max dimensions give you nearly 18 cu. ft (17.854), after wood thickness. Not sure what them 12's call for airspace but they would be getting somewhere around 2.75 gross each, which don't sound too bad. Wall these into the cabin, it could work.
Head Unit - Clarion VX709 7" DVD Touchscreen
Mid/Highs - Front Doors - RF Prime 6.5" component mids.
A. Pillars - RF Punch component tweets.
B. Pillars - RF Prime component tweets.
Rear Doors - RF Punch 5.25" mids.
RF Punch 3-way passive X-overs.
Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS.
Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider.
Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS.
Box - 9.6 cu^3 net @35Hz, three 6" aero's.
Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand)
Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
  • Who's Online   0 Members, 0 Anonymous, 6189 Guests (See full list)
