Zero_Tolerance_ Posted October 18, 2014 Report Posted October 18, 2014 I was finally able to wire up my brand new system which consists of a FI SSD 12 in a ported box being powered by a CT Sounds 1400.1. I'm about 95% sure that I wired everything correctly. Only thing I know of is that the paint on my ground isn't completely scraped away but its pretty close. I tested the voltage of my power wire and remote wire at the amplifier. Power was at 14 volts.. Remote at 12.. My inline fuse looks brand new, because it is. My amp light doesn't even come on.. Not quite sure what to do.
alaskanzx5 Posted October 18, 2014 Report Posted October 18, 2014 Better ground. Throw it in a friends car who already has a working amp to make sure its not the amp. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
jk13 Posted October 18, 2014 Report Posted October 18, 2014 Do you have the switch for HU turn on or bass knob turn on set right? Static drops are my bag.
SIDE SHOW Posted October 20, 2014 Report Posted October 20, 2014 check all the fuses and fuse connections
