Zero_Tolerance_ Posted October 18, 2014 Report Posted October 18, 2014 I figured out why my amp wouldn't turn on, but now even though it's on it doesn't power my sub at all. What should I test to figure out what the problem is?
reedal Posted October 18, 2014 Report Posted October 18, 2014 Use an oscope and test speaker outs to see if your amp is putting a signal out. Try a different sub. Try a different amp. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Zero_Tolerance_ Posted October 18, 2014 Author Report Posted October 18, 2014 Well I have none of those things so that doesn't exactly work.
OrionStang Posted October 18, 2014 Report Posted October 18, 2014 Without an oscope you're kinda fucked. Go get a cheap $10 model just to test voltage. Or take it to a shop and have them test it. Labor will probably cost more than the tool. SMD Super Seller My Feedback Thread
Zero_Tolerance_ Posted October 18, 2014 Author Report Posted October 18, 2014 Well I have a DMM.. That work?
OrionStang Posted October 18, 2014 Report Posted October 18, 2014 Well I have a DMM.. That work? Yes. Thats actually what I meant, but oscope was in my head from the previous post. LOL SMD Super Seller My Feedback Thread
Zero_Tolerance_ Posted October 18, 2014 Author Report Posted October 18, 2014 What is the right way to test the speaker outputs, then?
P4killer_ Posted October 18, 2014 Report Posted October 18, 2014 Just use a volt meter.. get a cheap one from harbor freight for free with coupon or like 3 bux if not. Set it ac volts at its lowest setting which I think on those is 200. Red wire to positive speaker terminal. Black wire to neg speaker terminal. Play music or tones. You should get a reading. A tone is better because itll be a constant value while the tone is playing. If not, it could be the signal. Make sure the rcas are plugged in. Your gain could be way low if you have a weak signal. So for the purpose of testing only, if your gain happens to be set real low right now turn it up to like half to test the voltage. Also make sure the lpf is set all the way up. Hpf all the way down. Ssf off or all the way up. For testing if the amp is putting out only. Reset everything to normal afterwatds. Double check all connections. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
OrionStang Posted October 18, 2014 Report Posted October 18, 2014 Disconnect speakers at the amp, set DMM to A/C voltage, play a test tone and see if the dmm reads anything. Positive probe to positive output, negative probe to negative output, obviously. SMD Super Seller My Feedback Thread
OrionStang Posted October 18, 2014 Report Posted October 18, 2014 And if you're using a bass knob or LC-1 make sure its turned up LOL. SMD Super Seller My Feedback Thread
