Amp doesn't power sub.
Make sure if you have master slave switch, its set to master. Also make sure the rcas arent plugged into the output side instead of the inputs.
Setup:
2010 Hyundai Elantra
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
DD M3b and 2 12" AQ HDC4s
So while listening to a 40hz test tone, I get no voltage at the speaker outputs on the amp. I tested the rcas as well and they have no voltage either. While testing I noticed it started to smell like something electrical was burning up. Everything is brand new. CT Sounds 1400.1 powering a FI SSD 12. All SHCA OFC wiring. Now what should I do?
  • Who's Online   0 Members, 0 Anonymous, 1100 Guests (See full list)
