Cannoy Posted October 22, 2014 Report Posted October 22, 2014 I recently used torres to build my second box for a friend, I just found out about end correction today and ive found several posts here about it and some say torres calculates this and some say it doesnt. What should i use to know my actually tuning frequency?
Joe X Posted October 22, 2014 Report Posted October 22, 2014 Torres factors in the end correction for slot ports, I mean look at the formula below, you don't need to be told by anyone, unfortunately Torres miscalculates port displacement so you usually still get 1-2Hz off from proper calculations with slot ports.
Cannoy Posted October 22, 2014 Author Report Posted October 22, 2014 i see how its off on the port displacement, on my next box can i figure out the difference and add that to like the bracing section to see the real frequency?
Joe X Posted October 22, 2014 Report Posted October 22, 2014 There's a way but none that I know from the calculator itself, it involves using Sketchup software to figure out your net volume and port centerline length, you can then enter that as net volume into Torres and enter the port dimensions, that way you bypass the flawed port displacement calculations, that being said the equation predicting tuning are ideal, significantly high or low temperature, port area ratio, any turns and other factors usually alter the theoretically predicted number.
philrab Posted October 22, 2014 Report Posted October 22, 2014 Kinda in the same vein the OP is thinking, my question is how far off is it typically? In statistics, we deal in variance. Everything we do in statistical analysis has a variance, or a margin for error, involved in it. It we're talking 1-2hz difference in port tuning frequency, unless you're chasing numbers competing, just doesn't seam worth worrying over. I'm not saying it doesn't make some difference, just saying I don't think it would drastically effect the final product. What do you think Joe X? Is there some merrit to that thought, or am I making light of it? 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
Joe X Posted October 23, 2014 Report Posted October 23, 2014 philrab 1-2 dB or 1-2Hz error is probably not going to make or break a daily system performance. It's a matter of personal opinion to assume or not that any calculator will do as differences in results can be considered negligible.
SQL50 Posted October 23, 2014 Report Posted October 23, 2014 1-2 hz higher or lower than the expected tuning frequency? More net volume or less net volume than expected after torres port displacement?
Joe X Posted October 23, 2014 Report Posted October 23, 2014 When Torres released his second revision of the software (2012) it became evident that there were discrepancies and people asked which was correct, here is a report on his thread: http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator-updated-818/page-27#entry2401303 The flaw is inconsistent for different box layouts so it's not possible to give a constant correction factor (for either version of the calculator), the second flaw is that it will miscalculate tuining for multiple round ports so when working with multiple round ports one should use the PSP.inc online calculator to determine correct tuning.
philrab Posted October 23, 2014 Report Posted October 23, 2014 philrab 1-2 dB or 1-2Hz error is probably not going to make or break a daily system performance. It's a matter of personal opinion to assume or not that any calculator will do as differences in results can be considered negligible. I guess that was my point. For your average daily system, Torres calculator gets you close enough that the rest is just splitting hairs. On the other hand, you could always use WinISD and get the port length/diameter info straight from there. 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
SQL50 Posted October 23, 2014 Report Posted October 23, 2014 I was modeling a box on Torres, and after all port displacements, sub etc was 7.55 cu ft net. It said that the port displacement was 3.14. Port dimensions 3 X 40.5 X 29.5= 3,584.25/1728= 2.07. Then for the displacement for the actual wood of the port. 0.75 X 40.5 X 25.75= 782.15625/1728= 0.45. 0.45+2.07= 2.52. Torres displacement was 3.14, so that minus 2.52= 0.62 cu ft more air net. Which interferes with the port area, and I would think the box would be seeing a lower tuning.
