No, Chad. bagged on 24's - Travis I belive did also, and gained.
Chad, sounds familiar...BTW Nov 2nd, Dip Tex
ill be there. not loud, but ill be there ;)
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Silvarado over here, in houston, went from 53.5 to 55 flat by wiring down and adding more electrical to handle it.
So he gained a 1.5 db from electrical upgrades and wiring down... Op doesn't have the electrical. Say he would drop to 11.8v wired @ 1ohms. Wire doe to .5 and drop to 10.5. What he could have gained by dropping doe went out the window with voltage drop.
If you can manage to keep voltage at the same point or higher with wiring down I could see a gain. If dropping voltage more and faster your hurting yourself. Would gave been better to do the big 3 and upgraded stock Bart to an agm.
well obviously I would advise OP to run .5 like in my post above.
Team Subsonic Lows
See you there, I'll have my 2 18s if you want a listen before they multiply into 4 18s. She's under construction so you may have to sit on the floor for the demo as I am currently riding super ghetto.
The L@zy Hoe
2005 Chevy Tahoe
2,500 Watts of Highs/Mids
4 10 midrange
4 6.5 midwoofers
4 Tweeters
6 Supertweeters
2 Lithium 80AH Batteries
24K Watts
4 Custom 18s
Quad alt setup Rebuilt 250amp and 3 370s
Interior work by Lone Star Auto Works
The Build Log
Like Loud Bass? Click Here!
On 12/5/2014 at 8:06 PM, juan777 said:
See yall there, I'll be the drunk Mexican with aviators on.
On 12/6/2014 at 10:32 PM, boom50cal said:
I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
Yeah but when he wired down an added batts did he meter before uping electrical and after?
If he didn't for all we know he could have gained 1db from wiring and .5 from electrical or vice versa.
What if the temp was different or batteries where charged better? Maybe his seat was moved slightly or his visor in a different position?
There are lots of variables that could make a difference there.
That as an example isn't very good.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
No one can guarantee what will happen when running outside of the manufacturer's specs. The amp is rated at 1 ohm. You want to run at half that. Your warranty is void, and YMMV - up to a fire and a full vehicle melt down. If you do it, do it knowing the risks.
Nikitaa typically suggests for noobs to run half ohm and be smart about it. It works for him and fantastic, there is nothing wrong with his first hand experience.
I won't suggest someone I DON'T know to run below rated impedance with shitty electrical. I don't want someone coming back and saying "you guys told me this would be fine and I fried my shit cause I'm stupid".
f***** it im getin 2 xs d3400s and ho alternator most likly mechman and gunna run that b**** at .5 ohm .my volts never drop below 13.8 at full tilt now and im wired at 2 ohm on a power sucker brz1200d im pretty sure my sundown will be more efficant anyways
