texasborn81 Posted October 25, 2014 Report Share Posted October 25, 2014 First off, I am new to this forum but i always read alot of informative posts here, so i decided to join. I would like some help with an enclosure for my wifes 2015 Sorento. I am working with 2.tang band 6.5 w6 1139sif and 75-100 watts each and would like to build a ported enclosure. The space i am working with is 42" wide, 7.5" tall, and depth I would like to keep to a max of 15". They will be firing forward under under rear seats. Slotted port would be preferred. I greatly appreciate any help with this project. Oh and i would like to use .5" mdf, unless .75" is recommended. Thanks Link to comment Share on other sites More sharing options...
Joe X Posted October 27, 2014 Report Share Posted October 27, 2014 A couple of low power 6.5s in a SUV seem to me like they are going to do next to nothing honestly, at those power levels I would just install a nice 3 way component set with good midbass on your doors and that would probably do the job just fine. Link to comment Share on other sites More sharing options...
Triticum Agricolam Posted October 27, 2014 Report Share Posted October 27, 2014 I did a box with four W6-1139SI subs on 400 watts in a crew cab pickup and they did well for what they were. However you are going to be 6 db below what I did in a much bigger cabin. Like JoeX said, you might not be real pleased with the performance. With the box I did I used .25 cubes per sub tuned to 32 Hz I believe. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds: Link to comment Share on other sites More sharing options...
bcbrassard Posted October 29, 2014 Report Share Posted October 29, 2014 I remember that box it turned out sick! Never did see vids of how it performed. OP your better off with 1 8" for a sub stage unless you already have the speakers, then make some 3-ways out of them. Link to comment Share on other sites More sharing options...
Soccerballzs Posted October 29, 2014 Report Share Posted October 29, 2014 You going for sql build sounds like? Will work for sql not spl. Run some Morels mids and tweets will sound good. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/ Link to comment Share on other sites More sharing options...
