"Big 3" question
so i just did the big 3 in my car... have a 90 amp alt and yellow top optima infront (nothing in back yet nor h/o alt)
before i did the big 3 ovcoarse i would get a little dimming of the lights but after install when the bass hits the dimming is waay more noticeable to the point where i can even notice it in my tail lights if i look closely enough..
is this normal after doing the big 3? I'm hoping you guys tell me its cus of my alt and no secondary batt. lol but its weird since it wasn't doing it before..
i removed a ground wire from the negative terminal to the frame (about 3 inches long) and just replaced it with 0 gauge ground.. someone told me that should be my problem but i didnt think that would make that happen.. idk lol
btw.. running a hifonics brutus elite 2500w amp for bass and some bullshit sub.. getting the car ready for my sundowns.
When doing the big 3 you should not remove anything just add to it. Also running a 2500 watt amp on stock electrical your going to have dimming.
Yes! never remove stock wiring, only add to it with the big 3.
Depending on the car you can replace completely. I had a 91 civic and when I did my big 3 I replaced the negatives and added onto the positive wire from the alt. Make sure all your connections are to bare metal.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Stock wiring is on the middle posts of this quad top Blue Top Battery i am running.
Better view of it. More like the big 5 on my setup.
my car is a 1990 toyota cressida so when i seen the small ass negative wire i was like... might as well just replace it and not bother back with it.. guess ill put it back. thankfully i didnt throw it away
What wires did you add for the big 3? You should alt+ to batt +, alt case to batt -, alt case to frame, batt - to frame.
Sometimes doing the big 3 can also cause your lights to dim worse as you are now giving the amp the ability to pull more current whereas before it was bottlenecked by your wiring.
That is technically the Big 4 lol, then there's also the Big 5 which is another one I can't remember. In my old 91 civic I dimmed more after the big 3 but had a higher voltage. Seemed contradictory but I said fuck it because all was good.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   0 Members, 0 Anonymous, 3140 Guests (See full list)
