OrionStang Posted October 26, 2014 Report Posted October 26, 2014 I am going to be running a true 3 way active front stage until I can afford new gear to add a subwoofer. I am using the Pioneer 80prs and Hertz tweeters, 3" mids, and 6.5" woofers. There is no subsonic filter built into the headunit, so how can I protect my 6.5's from frequencies under 55-60 Hertz? Would lowering all the EQ bands in the low range be sufficient? I don't want them to receive 30hz note at full volume LOL. SMD Super Seller My Feedback Thread
fox_racin4 Posted October 26, 2014 Report Posted October 26, 2014 That's what I would do myself. What if you used the amp to cut those freqs off? 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
OrionStang Posted October 26, 2014 Author Report Posted October 26, 2014 That's what I would do myself. What if you used the amp to cut those freqs off? Didn't even think of using the amp crossover. Thanks. My fucking brain just isn't working right the past few days LOL. SMD Super Seller My Feedback Thread
Jessica Posted October 26, 2014 Report Posted October 26, 2014 We have all tried to reinvent the wheel at one time or another. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
bcbrassard Posted October 26, 2014 Report Posted October 26, 2014 X2 on amp cross overs. I plan to use my amp to LPF a 200-60hz signal to the P3SD4-8s i plan to put in the kick panels. Signal jumped from pass thru on T400-2 for midrange driver which will be HPF on amp to run mids off 80-prs. Probly not coming out right but will be 3-way up front active - true TA
trumpet1 Posted October 27, 2014 Report Posted October 27, 2014 X2 on amp cross overs. I plan to use my amp to LPF a 200-60hz signal to the P3SD4-8s i plan to put in the kick panels. Signal jumped from pass thru on T400-2 for midrange driver which will be HPF on amp to run mids off 80-prs. Probly not coming out right but will be 3-way up front active - true TA I hate to rain on your parade but with one pair of RCAs feeding both your 8" subwoofers and midrange drivers you will not have separate time alignment. Also, there are so many better drivers to use for midbass than shallow subwoofers.
mothra Posted October 28, 2014 Report Posted October 28, 2014 if you amps crossovers don't work out for you, you can always put a non-polar cap inline. if nothing changes, nothing changes You don't know what you don't know, till you don't know
OrionStang Posted October 28, 2014 Author Report Posted October 28, 2014 if you amps crossovers don't work out for you, you can always put a non-polar cap inline. Amp x'over will work fine. Thanks for the suggestion though. SMD Super Seller My Feedback Thread
