Sergeant_Skyrim Posted November 6, 2014 Report Posted November 6, 2014 Not sure if anybody's mentioned it, but what's the Subsonic Filter on your amp set at? Does your H/U have a SSF as well? SSF will severely cut out frequencies below what you set it too, as a protective measure for your subs so they don't see full power if you accidentally play something too low. I may have missed whether this was mentioned, but definitely worth looking into if it hasn't been. That being said, last box I did tuned to 25hz after I played around with the port peaked around 40-41hz. Sometimes that's just the way it goes Build in progress
Joe X Posted November 6, 2014 Report Posted November 6, 2014 AstoSoup already had setup that same sub in a smaller vehicle with better results, pretty sure that you know your way around settings after a successful previous setup.
DylanBunch Posted November 6, 2014 Report Posted November 6, 2014 A c pillar in that won't be that skinny. I had one in my 06 with 2 15s and it was like 19" deep I think, maybe 18. I think he could pull it off, would also leave a good amount of room so the amps/batts wouldn't be crammed 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
