Cone Area vs Motor Force
Cj Kumz
that is a bold ass statement. What makes you think it will go lower???
because 2 12's add up to 24.. 18 being the lower number will hit lower
You have just confused the hell out of me!!
i was being dumb.. im, trying to figure out why people think larger subs get lower
OOH hah. Gotcha.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
I was always under the impression that the bigger the sub, the easier is was to play low notes. Not necessarily playing lows better, but more efficiently.
I will say this. Motor force definitely trumped cone area when I went from a DC Level 3 15 to a Tantric HD 12
Think about it this way...
If you could make everything the same except one set up was made up of 18s and another was made up of 8s would they have a different useable bandwidth?
I realize making those the same isn't really possible but use your imagination.
You say motor force, but you changed more than just the motor. How do you attribute the change solely to motor force?
F150:
Stock :(
Processor: DSR1
so your saying four 8's will play just as low as one 18? with a 18 you can always tune high and make decent upper bass, you cant hit 25hz with authority with 8's unless you have a massive amount of them
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
You can't say added cone area does not help with an extended bass-shelf.
With that logic a 1 inch speaker would be doing as well as an 18.
Yes it helps, but a 10 in a better design for low-end extensions will do better than an 18 in a cookie cutter box. However, if you have both in a proper enclosure they will be close to each other, but physics dictates that a larger cone area will have a higher output. Now I can't specify as to how far apart the two systems will be in response or if there is even an audible difference, but remember double cone area without maintaining constant power (ex: (1) 18" at 1kW or (2) 18"s at 500W a piece) will have the same output.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Agree completely. But again, if you have equal amounts of cone area it won't matter if it's 1 larger sub or a number of smaller ones. It does have to be a speaker designed to play at those frequencies though. A tweeter isn't designed to reproduce those frequencies.
But yes, an 18 will play lows louder than an 8, but not because its a bigger speaker, because its more cone area. Add 2 more 8s (or whatever amount makes the cone area similar) and all of the sudden lows are the same.
F150:
Stock :(
Processor: DSR1
of course you understand there are a lot more variables than just cone area, but all if everything else was magically the same, and the cone area of 4 8s was the same as the cone area of 1 18 then yes, the lows would be the same.
F150:
Stock :(
Processor: DSR1
some dude with 8-9 pyle 6.5" subs was showing them off in a thread not to long ago and everyone told him they wouldnt play low, which they didnt really. You can also get louder with 18's because when was the last time you heard of a 8" take anything more than 1k? the DD Z can take massive amounts of power, RE MT can to. you could have ten 8's on 10k watts or one 18 on 10k. its more cost effective depending what you buy aswell.
Lots of Second Skin
yeah, i understand where your coming from. I wish i lived in a world like that haha. everything would be so damn easy. :)
Lots of Second Skin
  • Who's Online   1 Member, 0 Anonymous, 5316 Guests (See full list)
