I don't think he's using the amps as master and slave. In which case you would set both with the dd-1.
im just saying MASTER and SLAVE as the ONE you set, and the one you MIRROR using the CC1
No linking no strapping
Try swapping your master and slave around.
I know when I just gain matched both my 4500s a couple days ago I used the DD-1+ to set BOTH amps, then I came back with the CC-1 and checked each amp.
1 of my amps makes about 5 more volts of power when set witth my dd-1+, So if i use the cc-1 to match off my louder amp, it instantly pushes my slave into clipping.
Alright I will take that idea also
Just want to make sure you have a good battery in the device like a Duracell, Rayovac, or Energizer, something decent and that it has decent amount of juice left in it right?
I dont know how many times this has happened and you ask the person and they say its a brand new Duracell in the device.
Then when they return the item because it does not work and Steve or Tony get the item back as a return or repair they check the battery first and its usually some dead battery reading 4 volts or some no name generic battery. They simply put a new quality battery in it and the device works just fine.
I myself replace my batteries in my DD-1, DD-1+, IM-SG, and CC-1 as well as my 2 clamp meters and my multimeter twice a year even if there is still life left in the batteries.
Just making sure this isnt the case here. ;)
  • Who's Online   1 Member, 0 Anonymous, 1822 Guests (See full list)
