I don't think he's using the amps as master and slave. In which case you would set both with the dd-1.
im just saying MASTER and SLAVE as the ONE you set, and the one you MIRROR using the CC1
No linking no strapping
Gotcha.
SMD Super Seller
My Feedback Thread
Try swapping your master and slave around.
I know when I just gain matched both my 4500s a couple days ago I used the DD-1+ to set BOTH amps, then I came back with the CC-1 and checked each amp.
1 of my amps makes about 5 more volts of power when set witth my dd-1+, So if i use the cc-1 to match off my louder amp, it instantly pushes my slave into clipping.
Alright I will take that idea also
Just want to make sure you have a good battery in the device like a Duracell, Rayovac, or Energizer, something decent and that it has decent amount of juice left in it right?
I dont know how many times this has happened and you ask the person and they say its a brand new Duracell in the device.
Then when they return the item because it does not work and Steve or Tony get the item back as a return or repair they check the battery first and its usually some dead battery reading 4 volts or some no name generic battery. They simply put a new quality battery in it and the device works just fine.
I myself replace my batteries in my DD-1, DD-1+, IM-SG, and CC-1 as well as my 2 clamp meters and my multimeter twice a year even if there is still life left in the batteries.
Just making sure this isnt the case here. ;)
