SA-12 Aero Port Help
mylesshivers
Hello, my max internal dimension are
h = 12.5
l = 29
w = 10.5
My subwoofer is an SA-12, form the research and googling I have done I have found that the xmax is 19 mm. one way and the displacement is .14 ft^3. I would like to tune it the the "all around/daily driver tune-age" @32 hz. The subwoofer will be powered by 1000 watts rms. If someone can determine if this is suitable and what the dimensions of my aero-port should be. Thank you.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
a 4" aero port full length in a box that is 2 cubic feet net.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
fuck aero port! go slotted port! lol
No
Hey with those dimensions your gross volume is 1.58 cubes and after woofer displacement that lives you with 1.44 cubes. Do a 4 inch port that's 23 inches long that should give you a tuning of around 32 hz with 10 sq inches per cube.
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
How did you get the wolume to be 1.58? I got 2.2..
Not a real way to determine correct port area.
Sorry my bad I think I didn't get the 'internal dimensions' part. In that case I would do a slot port that's 12.5 High, 2" wide and 37" long. That will give you a 1.4 cube box tuned to 32hz.. On the aeros side a 6 inch port will have to be way too long to tune that low. 4 inch port would have low port area per cube. Unless you can find a 5 inch port @ 26" that gives you 1.7 cubes @ 32". But since you overpowering I think the slot is better
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
  • Who's Online   1 Member, 0 Anonymous, 5316 Guests (See full list)
