SA-12 Aero Port Help
mylesshivers
Hello, my max internal dimension are
h = 12.5
l = 29
w = 10.5
My subwoofer is an SA-12, form the research and googling I have done I have found that the xmax is 19 mm. one way and the displacement is .14 ft^3. I would like to tune it the the "all around/daily driver tune-age" @32 hz. The subwoofer will be powered by 1000 watts rms. If someone can determine if this is suitable and what the dimensions of my aero-port should be. Thank you.
Krakin's Home Dipole Project
fuck aero port! go slotted port! lol
No
Hey with those dimensions your gross volume is 1.58 cubes and after woofer displacement that lives you with 1.44 cubes. Do a 4 inch port that's 23 inches long that should give you a tuning of around 32 hz with 10 sq inches per cube.
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
Not a real way to determine correct port area.
How did you get the wolume to be 1.58? I got 2.2..
Sorry my bad I think I didn't get the 'internal dimensions' part. In that case I would do a slot port that's 12.5 High, 2" wide and 37" long. That will give you a 1.4 cube box tuned to 32hz.. On the aeros side a 6 inch port will have to be way too long to tune that low. 4 inch port would have low port area per cube. Unless you can find a 5 inch port @ 26" that gives you 1.7 cubes @ 32". But since you overpowering I think the slot is better
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
  • Who's Online   0 Members, 0 Anonymous, 1135 Guests (See full list)
