DophieMan2013 Posted November 30, 2014 Report Posted November 30, 2014 With my 2014 explorer I have a 200amp alt and a stock battery. Im adding a BC3500D but am unable to upgrade the alternator or add a second. I was thinking of using a xs D3100 and 2 Farad 1000w caps? The explorer is only driven about 3-4 times a week. Any thoughts?
Miguels Posted November 30, 2014 Report Posted November 30, 2014 dont get those caps get the super caps. my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Miguels Posted November 30, 2014 Report Posted November 30, 2014 http://www.ebay.com/itm/like/181391254764?lpid=82 it will run about the same as those craps you want to get my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
rockFord_Expedition Posted November 30, 2014 Report Posted November 30, 2014 You'll probably do ok as long as you don't get on it too hard for too long and you aren't expecting the amp to do rated power. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
SnowDrifter Posted November 30, 2014 Report Posted November 30, 2014 270a alt and upgraded front battery should easily power your amp without the need for extra batteries or capacitors. This would be the ideal scenario at least... Why can't you upgrade your alt? What does your voltage look like now and what equipment so you have? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
DophieMan2013 Posted November 30, 2014 Author Report Posted November 30, 2014 http://www.ebay.com/itm/like/181391254764?lpid=82 it will run about the same as those craps you want to get I already had the caps but I can look into the other that you posted.
DophieMan2013 Posted November 30, 2014 Author Report Posted November 30, 2014 You'll probably do ok as long as you don't get on it too hard for too long and you aren't expecting the amp to do rated power. Hmmm.....looks like I need to come up with a solution.
DophieMan2013 Posted November 30, 2014 Author Report Posted November 30, 2014 270a alt and upgraded front battery should easily power your amp without the need for extra batteries or capacitors. This would be the ideal scenario at least... Why can't you upgrade your alt? What does your voltage look like now and what equipment so you have? From Matthew at Machman " the stock alternator is PCM controlled, not sure how much (if any) the alternator output could be increased without causing possible computer or battery light problems. We have not yet done a 2014 model, so I cant say for sure. Regards, Matthew" Also don't want to void the ford warranty. Crescendo BC3500D, xs D3100, 2 1 farad 1000w caps, 2 M3 Memphis mojo 15" (1k rms 2k peak) and the stock Sony 12 speaker 390 watt stereo. I'll have to back to you on the voltage.
bighossf150 Posted November 30, 2014 Report Posted November 30, 2014 I ran a bc3500 on a d6500, 2 xp3000's and a stock alt and it was fine. Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
Miguels Posted November 30, 2014 Report Posted November 30, 2014 270a alt and upgraded front battery should easily power your amp without the need for extra batteries or capacitors. This would be the ideal scenario at least... Why can't you upgrade your alt? What does your voltage look like now and what equipment so you have? From Matthew at Machman " the stock alternator is PCM controlled, not sure how much (if any) the alternator output could be increased without causing possible computer or battery light problems. We have not yet done a 2014 model, so I cant say for sure. Regards, Matthew" Also don't want to void the ford warranty. Crescendo BC3500D, xs D3100, 2 1 farad 1000w caps, 2 M3 Memphis mojo 15" (1k rms 2k peak) and the stock Sony 12 speaker 390 watt stereo. I'll have to back to you on the voltage. i already said it once this is the second time.. youre better off not using those caps. they dont actually work.. if youre looking for caps buy the ones i put a link of on my earlier post my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
