Weird box
quincyj34
Ok so Ill start with what I have. 92 F150 ext. cab, upgraded alt and wiring, Aq 1200d in the mail. Im looking at building a box that sits on the back seat like a center console so I can still have two people sit back. I have the design just need to know what I should put in it.I can get a about 3.0cu out of the max dimensions I have to work with and looking to tune anywhere from 32-35hz. The subs Ive been looking at are Sundown x12, Fi bl 12, or Sa-15. This will never be burped or anything like that but I do like some good bump. I listen to mostly rap and dubstep. Anyone have any suggestions?
Here is a side view of the box: Im thinking both the sub and an aero port firing up.
L=25in
______________
| | H=12in
| _________| Total height=22in
| | L=15in
|_____|
Width of the box max is 20in
A box on a seat will cause the seat to absorb output just to let you know.
With that said.
Figure out the inside volume with 3/4" wood.
If that is the 3cuft then a single 12 or 2 8s.
Remember the port, sub, and bracing all decrease net volume. If you're at 3cuft net with no sub(s), port, or bracing a 15" just wont work.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
I only came up with 3.05 cubes with the dimensions you gave. Out of the subs you listed, I don't think you'll have much luck getting a proper vent located in the box along with the sub.
I'd stick with a 10 or maybe two 8s, as was mentioned, because you're going to need a lot of vent area with the listed subs and you don't really have a way to make a long ass vent work in those confines.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
Just an idea for you, would you be able to find some captain seats to fit in the back instead of a single bench? That would free up some space i would think, give you the two seats you want, and you could build a box to fit between them firing up or forwards with adequate space for a good 12 after displacements i would think
I subtract two inches from each measurement when I figure rough calculations, as that usually accounts for vent displacement and gives a more accurate assessment of what the sub will actually have to work with. Of course, you also have to account for sub displacement but that's kinda hard to do when you don't know what sub you're using, lol.
Depends on the sub you use. 6" should be enough vent area for the Fi but I'm not sure about the X. Also, it's gonna have to be pretty long so...
  • Who's Online   1 Member, 0 Anonymous, 5384 Guests (See full list)
