Hey there, I have a 04 Ford Explorer and i was wondering if there is some way i can increase the idle by some sort of controller with out steping on the gas pedal or getting the mechanic to increase it via computer and keep it at a steddy rpm
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Pioneer AVH-P4900DVD
Clarion EQS746
AudioControl EPIC160
Kinetik HC2400
Put a brick on the pedal.
Take it out of drive tho.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
there should be a screw by the throttle body... just turn it either way and listen if it goes up or down, if ur engines seems like it idles lower turn it the other way... just keep turnin it like 1/8 of a turn at a time then go check ur rpm and keep increasin it till u get to where u like it.... i think the screw adjusts how for the throttle is open when not on the gas (correct me if i'm wrong ppl)
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
This ford explorer is Running Electronically.....so there is no screw by the throttle body the last time i check <_<
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
Yup thats why I like older cars not electronic throttle control, my car doesn't like to idle below 750rpm or it stutters so increased it to 900.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
oh ..kool koool.... the mechanic was telling me that i can use a Turbo Timer to increase my idle wen ever i want. But i was like to my self Turbo timer in an non turbo vehicle :S how does that work?!?
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
If you have a throttle body then you will have the screw. Its called a BISS screw check a local Explorer forum and they could prob show you exactly where its at. That is the only way to set the idle with out using a engine manager or controller. I'll try to look in my database for you.
Mark
99 Eclipse Spyder
Thanks Alot! ..........Is it possible for me to use a controller?
System specs
Beyma Pro 8MI (2)
Rockford P550.2
Rockford T20001BD
MTX 9512 (2)
HO Alt 200amp
BIG 3
Clarion EQS746
Kinetik HC2400
You can't use a turbo timer to up your idle speed unless you have a turbo the only way to change it is through the ecu or manually through the biss screw. What kind of controller do you have?
Edited by talentfinder36
Mark
99 Eclipse Spyder
I've been lookin for this for my 03 f-150 as well so that i can flip a switch to raise the idle up some when i am parked to keep the battery bank charged better. The smaller alternator pulleys just aren't enough. Hopefully someone here can shed some light on the situation. If the engine control unit for tuning is the only option then it is pretty expensive but you will be able to monitor performance as well.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
  • Who's Online   0 Members, 0 Anonymous, 2630 Guests (See full list)
