Door pods, third times the charm. (Finished!!!)
BigManAC
They will be bolted to the door panel that have bolts glassed to them. I will just attach the pod to the panel then the panel to the door.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
awesome. I might try the same method on my doors.
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
I figured that way if I needed to make new pods or add anything I can just simply make new pods and attach them.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Alrighty peoples, I have some good news and some bad news. The good news is that the pods are 100% done and in the car. The bad news.......no pics till tomorrow. Ill make sure to get tons of pics and maybe even a little video for you guys :good:
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Hello all. So I wasn't able to get some pictures today due to being busy and it raining all day. However, I was able to get a video tonight of them playing and a little distance test. Enjoy.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Here are some pictures of the finished and installed pods.
15B1A4B9-C7B7-4C22-A745-3F16DFD6C341_zps
8CE4F2E5-5439-476D-AD31-4AF29609BE09_zps
EBDED56C-1284-47EA-8CFD-47A85F7C0CE0_zps
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
You just...made that look so damn easy. Like it would take a couple days to do lol...happen to have any pics of how pods are bolted to panel on the backside? Still need to do mine for 2 PWX 6.5s per door AND keep the manual window crank...appreciate the pictures provided thus far though, practically a guide right here no words needed!
I wish I would have taken pics of that. Its one of those things where you do it and then sit back and say, "damn...should have taken a pic". The bolts are directly behind each speaker, one above and one at the bottom. I used 5/8" bolts with 2'' washers, one on the inside of the pod and the other on the backside of the panel. I bolted the pod directly to the panel and then just put the panel back on the door as normal.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
I would say on a scale of 1-10 im at a 8 on how these turned out. The only thing i would change is them contouring to the panels a bit better and having them wrapped. On one or two curves the radi are off just a tad but nothing you can see from stepping back and looking.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
  • Who's Online   1 Member, 0 Anonymous, 1828 Guests (See full list)
