i don't know what to do first?
I have 0gauge cca two dualast batteries three Kenwood amps one for mid and highs (720watts)one each(1800wattsx2) for my two dd2512s should i get two xs batteries (d6500 xp3000)first or mecham 270 alternator i can't afford both right now
I would suggest start with making correct sentences so we can understand what you need.
Now ... What type of vehicle are we working with here ???
Let me fix the grammar
So you currently have
- 1/0 cca power cable
- 2 Duralast batteries(I'm assuming wet cell)
- 3 Kenwood amps, 1 is a 4 channel for the front/rear stage, and the other 2 are monoblocks for a pair of DD 2512's
You are wanting to know if you should get an alternator or better batteries.
Me personally, I would say get the alternator first, even though it's not advised to run wet cell's inside a vehicle, just replacing those with better batteries will just keep you in 12's and will constantly need to be recharged, while with the 270, you can actually supply the current to power the system, and hold better voltage(not as well as you would if you had agm batteries with the 270 though)
Now if your batteries are in bad shape, then it would be a better idea to replace them then because even with a good charging system, bad batteries will bring your voltage down.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
i assumed he has 2 4channel amps. one for highs and one for mids
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
Thanks for the help.I am disabled.I will work on grammar.
2002 ford explorer
1 four channel
2 mono
I personally would get the alternator first, then upgrade all of your batterries later.
My Channel on YouTube. Check it out for cinematic-style Car Audio videos.
https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ
New 2014 Scion TC 4th Wall Build
https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
just busting your chops. texting has destroyed my spelling/grammar
what ohm load are you at?
if your at 1ohm with 3,600w on a 120amp alt... well I'm running 4k on a 120amp alt with 2 bats and my voltage is fine. except when I'm parked.
the alt first will be the cheapest way because 2 bats might do fine for now. but eventually you will want the alt. if you get the alt now you will prolly only need one good battery.
i would do alt first unless your bats are really bad
jvc deck
stinger 1800 front
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
lots of great stuff
coming soon
ho alt
more bats
more deadner
sweet amp rack
Each sub is duel 4 ohm wired at 2 ohm
Each amp is 900rms at 2ohm
I plan on upgrading.
Love bass!
I plan on getting.
1 3.5k dc
1 90.4 dc
I should of said this earlier.
  • Who's Online   0 Members, 0 Anonymous, 1403 Guests (See full list)
