Is it good or bad or crimp wires then solder?
The crimp looks as if its with a hex bit.
That does look like it would leave a similar looking crimp as a hex bit would
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
that head looks exactly how the wire i have was crimped.. im guessing the metal mart sticking out keeps the terminal from splitting or caving in
But here's the thing.... it's not going to be a solid piece like you would get with soldering or crimping a copper lug. And the wire strands on the end of that are exposed to moisture allowing water into your connection. And because it's not one piece, your connection is only as strong as the pressure the ears on that lug can provide without bending. Does it stay in place? Yeah probably. Is it a quality connection? Nope. Wouldn't cut it in an automotive application where you have a wide range of temperatures, humidity, vibration, and chemical exposure
yes you are correct but the argument here is which are made to crimp a which is to solder.. if they was to asked what terminal to use i would choose solid copper.. i have over 100 terminals that prove which are the best..
The other kind I've seen are open barrel connections like these
35782d1333568064-tlr-ground-wire-open-ba
Those are usually used for smaller wire. And when they are used, generally weatherproofed in some manner. While it may be acceptable for 16 and 18ga wires carrying low levels of current, it won't cut it for 0 gauge wire carrying a couple hundred amps. I've seen people solder them, but then you're back to square 1 of you should just solder in the first place. And good luck finding open barrel terminals/crimper in that size.
And that's the reason I asked.
I have the Rockford amp kits and over time they did get corrosion on them from being exposed. That is why when I reinstall I will put all new ends on. Soldered and heat shrink.
Just my preference.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Copper lugs can be either crimped or soldered. Soldering will be a bit different as you can't feed it in through the top, but it's still doable and with great results.
The open ended ring terminals are solder only. You may have seen people try to crimp them. I've seen my fair share. But just because it works today doesn't mean it will still be good tomorrow. Those connections go to poop quick on cars and hey presto now you have electrical problems
they are not solder ONLY.. yes i seen them fail but its due to not using the correct tool to get the job done right.. fosgate crimps them and a shop i used crimp them and they are solid connection. though i would solder to seal out the elements.. you have to use proper tools to get any job don right.. you cant torque heads down without a torque wrench.. just like you dont crimp with a hammer and pliers
No you crimp with pliers and a clamp.
when I use split lugs I crimp it just to hold the lug on the wire then i
solder them.
Next go around I'm buying a hydraulic crimper and copper lugs.
  • Who's Online   0 Members, 0 Anonymous, 981 Guests (See full list)
