fuse blown
your names fits right in
are you trolling us? you got a 4 gauge kit with a 5 amp fuse? why would you run a 2000 watt rating wire on 2600 watts? get 1/0 wire and make it ofc. your power rating puts you border line with cca
Try a 10a fuse and see if it keeps popping.
Do not go more than 20a cause your wire will probably not support that much draw and melt and start a fire.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
the fuse is for the one for the car
you have a short or you left a wire loose.. check your wiring also check the connections on the fuse panel see if they dont move with vibrations.. do not i repeat DO NOT try and fix the issue with a larger fuse rating
ok ill try find the source of the problem
Miguel is right find the problem don't use a larger fuse.
no just no.. thats the worst advice you can give someone.. if he has a short he will catch that car on fire before it blows the fuse.. someone replaced a 15a fuse in my expo that kept blowing out with a 20a.. yeah it worked for a few days till the short burnt all my wiring
  • Who's Online   0 Members, 0 Anonymous, 4212 Guests (See full list)
