Issue with subs
ImEnNergy
why are you running different kinds of subs?
is it a sealed box ported? shared air... i just don't get it. and running 3 subs the way you say you are you can't get a even ohm load.
i bet your gain is to high, and your ground isn't all that great.
where on the vehicle Is your ground, and how did you set your gain?
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
You have two D4 subs, unless I'm missing something. You're not wired to 2 ohms.
Three D4 subs... Lol
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=3&I=42#results
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
Ported box, believe i need to drill a hole and connect the subs, I have them all wired the same but I dont have a wire connecting each of them and yes I think it's actually like 4 ohms or maybe even 6 the way i have it wired, my buddy helped me wire them which wasn't a good idea. the ground is also connected to a bolt underneath my back seats. It's wire brushed pretty good, and the best spot I could find for a ground.
1 Sundown Sa-12
2 NvX VCW124's
Hifonics brutus 2200.1d
02 F150
they all share the same box?
Yes, if you check out the video I posted the sundown would be in the middle with the two NVX's on the sides.
1 Sundown Sa-12
2 NvX VCW124's
02 F150
here are your 2 options
I would remove either the sa-12 or the nvxs and see if the problem is still there....
Everything is wired correctly down to 2-ohms thanks for the help everyone, they no longer make that noise when you crank the bass knob to make the panties wet.
1 Sundown Sa-12
2 NvX VCW124's
02 F150
  • Who's Online   1 Member, 0 Anonymous, 5384 Guests (See full list)
