Kade Posted December 27, 2014 Report Posted December 27, 2014 Working on a 2007 Grand Prix this morning. The only factory spot to ground in the trunk is on top (I think) the gas tank. There are 3 bolts and this weird cookie cutter looking piece in the center of them. No Idea what It is. All I know if on the other side of the wall (outside the car), the gas cap sits. Edit: Found the gas tank. I think we're good. Wtf is that 3 bolted object in the trunk on the drivers side of the car then? 2009 Dodge Caliber SXT (Silver) Deck: Pioneer X3600BHS Amps: RF P1000X5 Front: RF P16-S Rear: RF P1694 Subs: 1 RF P3D2-10 Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire. Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
Kade Posted December 27, 2014 Author Report Posted December 27, 2014 I'm an idiot. Those 3 bolts are for the struts. Even still. Good grounding spot? 2009 Dodge Caliber SXT (Silver) Deck: Pioneer X3600BHS Amps: RF P1000X5 Front: RF P16-S Rear: RF P1694 Subs: 1 RF P3D2-10 Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire. Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
zoeboi954 Posted December 27, 2014 Report Posted December 27, 2014 struts are great grounding spots avoid the gas tank as much as possible i accidentally drilled an hole in my old car gas tank to screw down my amp man i had so much engine problem 4 Fi Q 12s In A Prius on 4 Crescendo BC2000D?! That's Absurd (!!!UNDER CONSTRUCTION!!!) go follow http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/
Kade Posted December 27, 2014 Author Report Posted December 27, 2014 struts are great grounding spots avoid the gas tank as much as possible i accidentally drilled an hole in my old car gas tank to screw down my amp man i had so much engine problem My next guess to anchor down the ground would have been right on top the gas tank. Luckily "2007 Grand Prix Trunk Parts" on google gave me what I needed. Never would've guessed struts. Not a mechanic at all. 2009 Dodge Caliber SXT (Silver) Deck: Pioneer X3600BHS Amps: RF P1000X5 Front: RF P16-S Rear: RF P1694 Subs: 1 RF P3D2-10 Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire. Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
Afficionado Posted December 27, 2014 Report Posted December 27, 2014 Yes, struts are a very good place to ground too. If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved.
TRON Posted December 27, 2014 Report Posted December 27, 2014 If there's a lot of rust around the strut, I'd consider a different spot. The rust may be all the way through the metal and you wouldn't be able to see it. Just a thought. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
gckless Posted December 27, 2014 Report Posted December 27, 2014 I try and keep gas and mass amounts of current as far away from each other as possible. Just me. "Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand. My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/ High resolution photos: Gilbert Kless Photography
Dragonware Posted December 27, 2014 Report Posted December 27, 2014 I'm an idiot. Those 3 bolts are for the struts. Even still. Good grounding spot? This made me LOL My Build log : http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/ Current System 2020 Ford F-150 XLT Supercrew Audio Control Epicenter Audio Control LC7i Taramp PRO 2.6 DSP Taramp DS4x800 - Highs Taramp HD3000.1 Mids Taramp MD5000.1 Bass 8 x DS18 6.5 Pro x6m - mids 2 x Soundsteam SST-05 Bullet Tweeter 2 x DS18 TW220 Super Tweeters 4 X SkarAudio EVL-8 BASS Big 3 Yellow Top
Jessica Posted December 27, 2014 Report Posted December 27, 2014 why arent those nuts tight? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
