Grounding to gas tank safe?
Working on a 2007 Grand Prix this morning. The only factory spot to ground in the trunk is on top (I think) the gas tank. There are 3 bolts and this weird cookie cutter looking piece in the center of them. No Idea what It is. All I know if on the other side of the wall (outside the car), the gas cap sits.
Edit: Found the gas tank. I think we're good. Wtf is that 3 bolted object in the trunk on the drivers side of the car then?
2009 Dodge Caliber SXT (Silver)
Deck: Pioneer X3600BHS
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire.
Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build
Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
I'm an idiot.
Those 3 bolts are for the struts.
Even still. Good grounding spot?
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
struts are great grounding spots
avoid the gas tank as much as possible i accidentally drilled an hole in my old car gas tank to screw down my amp man i had so much engine problem
4 Fi Q 12s In A Prius on 4 Crescendo BC2000D?! :WTFBubble: That's Absurd (!!!UNDER CONSTRUCTION!!!) go follow http://www.stevemeadedesigns.com/board/topic/190658-the-first-prius-with-4-12s/
c42977d4-a28f-47b5-a02f-49dbb8697b2d_zps
My next guess to anchor down the ground would have been right on top the gas tank. :ehh:
Luckily "2007 Grand Prix Trunk Parts" on google gave me what I needed. Never would've guessed struts. Not a mechanic at all.
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
If there's a lot of rust around the strut, I'd consider a different spot. The rust may be all the way through the metal and you wouldn't be able to see it.
Just a thought.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I try and keep gas and mass amounts of current as far away from each other as possible. Just me.
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
I'm an idiot.
This made me LOL
My Build log :
http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/
Current System
2020 Ford F-150 XLT Supercrew
Audio Control Epicenter
Audio Control LC7i
Taramp PRO 2.6 DSP
Taramp DS4x800 - Highs
Taramp HD3000.1  Mids
Taramp MD5000.1 Bass
8 x DS18 6.5 Pro x6m - mids
2 x Soundsteam SST-05 Bullet Tweeter
2 x DS18 TW220 Super Tweeters
4 X SkarAudio EVL-8  BASS
Big 3
Yellow Top
  • Who's Online   1 Member, 0 Anonymous, 1374 Guests (See full list)
