How important is the head unit?
Jskiles
Say I have a radio that I am using outside the vehicle only for burps just competing with. How important of a role does it play since it only has one purpose? I plan on buying a new one later anyway, but I would like to hear everyones opinion.
2010 Kia Forte Koup (Slow Build)
2 Sundown SCV-3000D
2 DC XL M1 with PSI recones
Focal R-165s2 on Orion 4800-HP
Kenwood KDC-X798
Knukonceptz OFC 1/0
Audiotechnix,Fatmat and Q-mat Deadener
XS power D3400 up front 3 D3100s power in trunk
Stock 110 amp alt
2013 Scion TC
2 Dc lvl 3s with xl coils on Soundqubed 2200
Sundown components
AA 50.2 for components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
XS Power D3100 up front D925 in back
Mechman 240 alt
http://www.stevemeadedesigns.com/board/topic/189911-2013-scion-tc-build/ <Scion TC Build
http://www.stevemeadedesigns.com/board/topic/174094-jskiles-forte-koup/ <Slow Kia Forte Build
http://www.stevemead...ockUserAgent__1 < Old build 2005 Equinox
Don't understand your question.
Every system no matter what application has to have a source unit of some type ...
Depends .. On output voltage etc
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Important for what?
Just for burps?
Doesn't matter.
Yeah just burps.
Its a shitty sony that I was going to use for testing until I got a better one
I know that every application has to have a source unit. Its pretty much a stupid question.
2 Sundown SCV-3000D
Kenwood KDC-X798
Knukonceptz OFC 1/0
Stock 110 amp alt
2013 Scion TC
Sundown components
Pioneer FH-X700BT
Knukonceptz OFC 1/0
Mechman 240 alt
Output voltage doesn't matter when you are talking about output from the amp. That's what gain matching is for. Now output voltage can make a difference depending on the setup. More voltage going through that RCA's can help if there's any interference. The same amount of interference will still be present...but the distortion percentage of a higher voltage will be lower. But this doesn't matter for short burps.
AA98Hoe was supposed to answer since he said it.
(But honestly, there shouldn't be any interference to begin with.)
And as you said, it doesn't matter for burps, you could even use a cellphone. (or even better a signal generator.)
What can be handy is a pauze button on the headunit.
some competitors like to "roll" the volume up which is easiest done with a turn dial style volume knob....
Yep, used my xo3 for this
  • Who's Online   0 Members, 0 Anonymous, 1254 Guests (See full list)
