2011 Honda Accord Sedan(Slow Budget Build)
Appreciate it........The thing is I really don't want to run two per side its just lets be real those speakers are weak. You think they could keep up.Even tho they will only be playing Mid-bass.
One can be plenty loud and it's a whole lot less complicated install.
That will be personal preference, there are benefits and disadvantages to either way so just pick what will work best for you.
No they wont keep up, you are asking a 6.5" driver to make midbass that will keep up with a 12" subwoofer. Plus none of those drivers are true midbass, they are midrange just like the sealed backs but play lower than 200/300hz but you wont get any real midbass from them. There are some pa speakers that will produce some midbass but they will have to be ported.
I was using 14 Eminence Alpha-6. Then started experimenting with different brands and types of speakers and learned that certain brands get louder than others such as O2, Beyma etc. I had one 02 Audio sealed back that got as loud as all the Emience but that's all it did was get loud, nothing else. With subs they will sound good cause you hear the vocals clear but without subs listening to a system filled with pa speakers can be a nightmare.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Why not go with a single 8" or 10" in the door, instead of multiple speakers cancelling each other out while trying to accomplish the same goal.
AudioControl DM-608
Worked on the carpet in the trunk I can honestly say never again.lol Shit was so aggravating
It's not all the way in just test fitted it. still got some patches to fill in.
