2011 Honda Accord Sedan(Slow Budget Build)
Alright I started some wiring today. I really like to have my wiring real clean I cant stand when wires are all over the place and not wired clean. Thats just me tho.
I did go a lil overkill with zips tie tho lol
(WIRE GAUGES)
BULLET TWEETERS~(16 GAUGE)
MID-RANGE~(14-12 GAUGE)........12 Gauge running from the amp then splits into 2 runs of 14 gauge since there will be 2 Speakers per channel.
MID_BASS~(12 GAUGE)
SUBS~(10 or 12) Not sure yet.
12 GAUGE
OLD 14 GUAGE
16 GAUGE
MID BASS 12 GAUGE single run since it will be bridged.
Passenger side) 12 GAUGE running through for 8"MID BASS by kick panel.
Intersection of dual 14 gauge to single 12 gauge for MID RANGE. Also dual 16 gauge to single 16 gauge for BULLETS.
Intersections tucked and zip tied away.You can also see the MID BASS 12 gauge run ready to be bridged to the CONCEPT CC-1002 Amplifier under the passenger seat.
Driver side getting worked on. You can see the MID BASS drivers 12 Gauge wire coming through the foot rest in the background.
Lots of zip ties.
Driver side intersection tucked away.
I wouldn't have used all those butt connectors but other than that looks like you did a good job.
I don't like them either ,only reason I did it like this because when I made the door pods I only ran the wire just long enough to get through the door grommet. I dont know why I just didn't make the runs long enough to reach the amps but it's gonna have to do for now because I really do not feel like taking off the pods and running it again.
your doin good man keep it up
2000 blazer LS
240 mechman
2 b2 HN v3 15s
crescendo bc5500 @.5
1/0 ebflex ofc
d680/g31
kenwood deck
mb quart components
crescendo pwx 8s
lots more to come
blazer build http://www.stevemeadedesigns.com/board/topic/204432-shadowcasters-2k-blazer/
142.8db MECA
2016 PA state champ mod 1 class
Then the sealed backs will be pointless, I dont like two different speakers playing the same frequencies.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Worked on the trunk a little bit more today. Got everything plotted out as far as were the fuses and wiring and stuff like that is going to go. Also found a spot to mount the fourth AMP.
