Bump4life Posted January 13, 2015 Report Posted January 13, 2015 charger. ctek 7002. make sure you dont have a parasitic draw. test my getting multimeter. or clamp meter with milli amp setting, and testing draw on battery with car off. guess that would be faster then doing it how i said lol all you have top do is disconnect battery negative. put multimeter in amperage mode and connect postive (red wire) to battery ground and negative (black wire) to car ground. and it should give you an amperage draw reading. if its too much and blows multimeter amp fuse well you have some serious parasitic draw clamp meter is much easier though and requires no removing of wires Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Ninja_v1.0 Posted January 13, 2015 Report Posted January 13, 2015 My 3400 up front has been a fucking boss............ no bulge, no warp,.. holds 12 plus all day....with multi alts under the hood (heat, and pull) . and its 2 years old... fucking thing just keeps going..... and its 7 degrees here.... and will be well below zero .. soon.... edit- if i dont keep my charger on the bank (havent started, let a lone drove the blazer in weeks) i do see mid 11v numbers.. You sure you "meter or whaever" is legit? why do your responses have 6,326,956 lines in them ? When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
YukonDCXL Posted January 14, 2015 Author Report Posted January 14, 2015 I just ordered the ctek 7002... so just set to normal and let it charge away? can I charge as much as I want to?
Bump4life Posted January 14, 2015 Report Posted January 14, 2015 I just ordered the ctek 7002... so just set to normal and let it charge away? can I charge as much as I want to? if its xs power set to snow flake for agm. read user manual. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Kyblack76 Posted January 14, 2015 Report Posted January 14, 2015 My 3400 up front has been a fucking boss............ no bulge, no warp,.. holds 12 plus all day....with multi alts under the hood (heat, and pull) . and its 2 years old... fucking thing just keeps going..... and its 7 degrees here.... and will be well below zero .. soon.... edit- if i dont keep my charger on the bank (havent started, let a lone drove the blazer in weeks) i do see mid 11v numbers.. You sure you "meter or whaever" is legit? why do your responses have 6,326,956 lines in them ? Your Mutha.... It's when I use my iPad. Meh. Deal with it SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
YukonDCXL Posted January 15, 2015 Author Report Posted January 15, 2015 I just ordered the ctek 7002... so just set to normal and let it charge away? can I charge as much as I want to? if its xs power set to snow flake for agm. read user manual. Ill re read the xs post but I think it said to charge at 14.4v... isnt that the normal mode?
YukonDCXL Posted January 15, 2015 Author Report Posted January 15, 2015 and I just re read... xs says to charge at 14.4v for 12v batteries and the instruction manual to the ctek 7002 says normal mode charges at 14.4, and snowflake charges at 14.7. So unless I am misreading something then you are wrong.
