XS d3400 dropping to 11.9 volts
I recently installed a d3400 and when I received the battery is was sitting steady at 12.6 volts. I have been noticing in the morings it is down to around 11.8 but it has been dropping a little below 30 degrees at night... is this normal?
Do you ever charge it on a charger
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
My 3400 up front has been a fucking boss............
no bulge, no warp,.. holds 12 plus all day....with multi alts under the hood (heat, and pull)
. and its 2 years old...
fucking thing just keeps going.....
and its 7 degrees here.... and will be well below zero .. soon....
edit- if i dont keep my charger on the bank (havent started, let a lone drove the blazer in weeks) i do see mid 11v numbers..
You sure you "meter or whaever" is legit?
I have never charged it. Hooked it up had system playing for a few days with and but the last week no system playing at all. I use my smd vm-1 to check my voltage and when I just turn the key on in the morning it reads below 12. How can I get a good charge to it without spending a few $100 on charger?
Charge it regularly. I have two d3400s under the hood and at -35c (-31f) I could probably drive on the starter.
I charge once every two weeks though, because my commute to work is short.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
definately invest in a charger.
as a noob to battery maintanence, i learned that even tho the alternator is supposed to recharge the battery, it doesnt actually charge it like an actual charger does. look into the ctek 7002, 120$ off amazon. bad ass little charger. keep up on your batts! it does make a huge difference.
You might have a parasitic draw on it
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
i would look into to make sure u dont have something drawing on it causing it and also if your alt is charging right and putting out the right amount of amperage my d3400 has been in my truck for 5 years and still going strong
  • Who's Online   0 Members, 0 Anonymous, 4231 Guests (See full list)
